Hi Nalaka,
You have 2 choices to avoid that error:
1) Do what Keith suggested, install the sequencer package and edit configure/RELEASE to point to it.
2) Comment out the line in configure/RELEASE that defines SNCSEQ by placing a "#" character at the start, like the following:
#SNCSEQ=$(SUPPORT)/seq-2-1-10
If you do that and then run "make" at the top-level in asyn it will not build the testIPServerApp directory, and you will not get the error.
-----Original Message-----
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Keith Thorne
Sent: Wednesday, December 26, 2012 7:20 AM
To: nalaka samarasinghe
Cc: tech-talk@aps.anl.gov
Subject: Re: Error in installing asyn driver
Dear Nalaka
I am an EPICS user, not developer. But I think I can help here.
To convert ipSNCServer.st to ipSNCServer.o for asyn, you need to
first install the sequencer and SNL (State Notation Language) compiler.
- Look in EPICS modules list for sequencer (Now maintained by BESSY staff)
http://www-csr.bessy.de/control/SoftDist/sequencer/
Once you install that, edit the configure/RELEASE file so the SNCSEQ macro points to that installation location
Keith Thorne
On Dec 25, 2012, at 11:20 AM, nalaka samarasinghe wrote:
> Dear Sir,
> When i am trying to build asyn package,following error appears. Please kindly let me know where i have gone wrong.I have successfully installed EPICS base.
> Thanks & Regards,
> Nalaka Samarasinghe
> Please see the output below:
> nalaka@nalaka-laptop:~/opt1/epics/modules$ cd asyn
> nalaka@nalaka-laptop:~/opt1/epics/modules/asyn$ make
> make -C ./configure install
> make[1]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/configure'
> perl /home/nalaka/opt1/epics/base/bin/linux-x86/convertRelease.pl checkRelease
> make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/configure/O.linux-x86'
> make[2]: Nothing to be done for `install'.
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/configure/O.linux-x86'
> make[1]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/configure'
> make -C ./makeSupport install
> make[1]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/makeSupport'
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/makeSupport/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/makeSupport/O.linux-x86'
> make[1]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/makeSupport'
> make -C ./asyn install
> make[1]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/asyn'
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/asyn/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/asyn/O.linux-x86'
> make[1]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/asyn'
> make -C ./testApp install
> make[1]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp'
> make -C ./src install
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp/src'
> make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
> make[3]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp/src/O.linux-x86'
> make[3]: Nothing to be done for `install'.
> make[3]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp/src/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp/src'
> make -C ./Db install
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp/Db'
> make[3]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp/Db/O.linux-x86'
> make[3]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp/Db/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp/Db'
> make[1]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testApp'
> make -C ./testGpibApp install
> make[1]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp'
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp/src'
> make[3]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp/src/O.linux-x86'
> make[3]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp/src/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp/src'
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp/Db'
> make[3]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp/Db/O.linux-x86'
> make[3]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp/Db/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp/Db'
> make[1]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibApp'
> make -C ./testGpibSerialApp install
> make[1]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibSerialApp'
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibSerialApp/src'
> make[3]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibSerialApp/src/O.linux-x86'
> make[3]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibSerialApp/src/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibSerialApp/src'
> make[1]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testGpibSerialApp'
> make -C ./testEpicsApp install
> make[1]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp'
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp/src'
> make[3]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp/src/O.linux-x86'
> make[3]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp/src/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp/src'
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp/Db'
> make[3]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp/Db/O.linux-x86'
> make[3]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp/Db/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp/Db'
> make[1]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testEpicsApp'
> make -C ./testManagerApp install
> make[1]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testManagerApp'
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testManagerApp/O.linux-x86'
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testManagerApp/O.linux-x86'
> make[1]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testManagerApp'
> make -C ./testIPServerApp install
> make[1]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testIPServerApp'
> make[2]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testIPServerApp/src'
> make[3]: Entering directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testIPServerApp/src/O.linux-x86'
> make[3]: *** No rule to make target `ipSNCServer.o', needed by `libtestIPServerSupport.a'. Stop.
> make[3]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testIPServerApp/src/O.linux-x86'
> make[2]: *** [install.linux-x86] Error 2
> make[2]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testIPServerApp/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `/home/nalaka/opt1/epics/modules/asyn-4.10/testIPServerApp'
> make: *** [testIPServerApp.install] Error 2
Keith Thorne <kthorne@ligo-la.caltech.edu>
CDS Software Engineer
LIGO Livingston Laboratory
Livingston, LA 70754
Phone: (225)686-3168 Fax: (225)686-7189
unable to see epics variables James F Ross
Question from the dark past: CGIExport Maren Purves
<2013>
Re: unable to see epics variables James F Ross
RE: Error in installing asyn driver Mark Rivers
<2013>
