Hi Jon,
It's an interesting question, and I'm sure the 'best' solution (if there is one!) will depend on your application.
When I am doing serial comms e.g. StreamDevice, I try to keep the number of periodically scanned records to a minimum. For example, I might use a fanout record with SCAN .5 second linking to PASSIVE records which actually do the work. This means that if I want to change the scan rate I only need to change a single record, or I can turn off comms altogether by disabling just this one record.
I've personally never used the PHAS field, and someone can correct me but I think this is not usually recommended?
As for 'push' vs 'pull', I'm never quite sure which to use either. Unless I really need event driven processing (e.g. to catch every update from a device), I usually tend towards the pull approach. I find this is best for flexibility for adding functionality later on, otherwise I end up with long chains of FLNKed records which I try to avoid as it creates dependencies between tasks which are not necessarily related.
Just my thoughts on the subject anyway!
Cheers,
Emma
> -----Original Message-----
> From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-
> bounces@aps.anl.gov] On Behalf Of jon@u.washington.edu
> Sent: Friday, 21 December 2012 5:30 AM
> To: tech-talk@aps.anl.gov
> Subject: Record processing: periodic vs. push vs. pull
> One of the EPICS Getting Started slide decks (ref below) discusses
> alternatives for record processing in a chain of three records where
> data flows: ai VAL -> INPA calc VAL -> DOL ao. The alternatives are:
> 1. Periodic: all three records have SCAN .1 second, with advancing
> phase:
> ai PHAS 0 -> calc PHAS 1 -> ao PHAS 2
> 2. Push: input ai record is periodic, others are passive, with forward
> links:
> ai FLNK -> calc FLNK -> ao
> 3. Pull: output ao record is periodic, others are passive, with input
> links
> INP and DOL with PP attribute (here arrows show control not data
> flow):
> ai <- INPA PP calc <- DOL PP ao
> I wonder how to choose among these. I can think of these pros and
> cons:
> 1. Periodic
> Pro: i. Record definitions do not depend on control flow, no INP PP or
> FLNK
> ii. No control flow subtleties, records always processed on fixed
> schedule
> Con: i. Processing occurs on fixed schedule, regardless of events or
> demand
> ii. Might have to tweak control flow after all, with PHAS
> 2. Push
> Pro: i. Processing can be driven by events, when data appears or
> changes
> (in input ai, replace SCAN .1 second with I/O Intr or ...)
> Con: i. Input record definitions depend on downstream data processing
> (must anticipate where data will be consumed to define FLNK)
> 3. Pull
> Pro: i. Processing can be driven by demand
> (in output ao, replace SCAN .1 second with input from FLNK or
> ii. Input record definitions do not depend on downstream
> processing
> Con: i. Control flow may be difficult to analyze or understand, for
> example
> INP PP gets old value instead of waiting for asynchronous
> completion
> INP PP flag ignored in CA links (to other IOCs), behaves like
> NPP
> Have I overlooked any important pros or cons? Is there one alternative
> that is more common, or one that is recommended (or discouraged)?
> Jon Jacky
> PS - The three alteratives appear in slide 29, "Processing chains", in:
> What is an EPICS database? Andrew Johnson 2004
> http://www.aps.anl.gov/bcda/epicsgettingstarted/iocs/Database1&2_1up.pd
> f
- Record processing: periodic vs. push vs. pull jon
CSS XY Graph Pause John Dobbins
Re: CSS XY Graph Pause Pavel Maslov
<2012>
Re: Record processing: periodic vs. push vs. pull Andrew Johnson
<2012>
