If you "escape to C" the .h with "%%" then you'll have to do the same with your struct declaration.
cc-ing tech-talk for further comments from others.
Sent: Thursday, December 20, 2012 6:07 AM
To: Zelazny, Michael Stanley
Subject: structs and SNL
Hi Michael,
I think that I understand reentrant to mean (in part) that variables in SNL and C-code
can be related. Assuming that is true, then I'm attempting to implement the section
"Variable Modification for Reentrant Option". My C code reads our database and I
would like to use some of the variables from there in an entry block of a particular
state.
So, in the top-level declarations I define a number a variables which have the same
declaration as those in a struct in a header which I include in the top-level with %%
escape:
option +r;
%%#include "MICEStates.h"
char name[50];
If I understand the documentation, I should be able to do:
struct PV *cPV;
where PV is the name of my struct in the header file (I also tried UserVar, as
in the example). However, at compile time, I get the error "type specifier".
This error follows the "struct" statement wherever I put it in the code.
Can you tell me what I'm doing incorrectly?
Thank you.
Pierrick--
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
- RE: structs and SNL Mark Rivers
- SNL with C Pierrick M Hanlet
- RE: SNL with C Zelazny, Michael Stanley
- Re: SNL with C Pierrick Hanlet
Re: [makefile] adding a library to an EPICS application Ralph Lange
Record processing: periodic vs. push vs. pull jon
<2012>
<2012>
