1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [makefile] adding a library to an EPICS application
To: EPICS Tech Talk <[email protected]>
Date: Thu, 20 Dec 2012 13:22:57 +0100
On 20.12.2012 12:55, Pavel Maslov wrote:
> As strange as it may seem, though
> DB_INSTALLS += xxx.db
> works without specifying the full path, provided all the files are in
> ./, whereas for any other file extension it requires the full path to
> that file.
Yes, correct.
For BESSY we have been using our own rules for a long time, and
something we added there was
# GENERIC_INSTALL_RULE should be called with 3 or 4 arguments:
# $1 extension
# $2 description of file type
# $3 where to install
# $4 (optional) extra vpath dirs
define GENERIC_INSTALL_RULE
vpath %.$1 $(USR_VPATH) $(GENERIC_SRC_DIRS) $4 $(COMMON_DIR)
$3/%.$1: %.$1
        $(ECHO) "Installing $2 file $$(@F)"
        @$$(INSTALL) -d -m 644 $$< $$(@D)
endef
so you can add the rules to install other file types by using the macro
like (example for .proto files, we actually added ~10 files types we may
want to install)
$(eval $(call
GENERIC_INSTALL_RULE,proto,protocol,$(INSTALL_DB),$(RELEASE_DBSEARCHDIRS)))
The 4th argument sets the search path to the db dirs of all modules in
RELEASE, so after adding this block to the rules, a definition in you
App's Makefile
DB_INSTALLS += xxx.proto
will look for xxx.proto in the db subdirectories of all modules defined
in RELEASE files.
Cheers,
~Ralph
[makefile] adding a library to an EPICS application Pavel Maslov
RE: [makefile] adding a library to an EPICS application Mark Rivers
Re: [makefile] adding a library to an EPICS application Andrew Johnson
Re: [makefile] adding a library to an EPICS application Martin Konrad
Re: [makefile] adding a library to an EPICS application Pavel Maslov
Re: [makefile] adding a library to an EPICS application Ralph Lange
Prev: Re: [makefile] adding a library to an EPICS application Pavel Maslov
Next: RE: structs and SNL Zelazny, Michael Stanley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: devlib2 bugfix (rare string corruption) Till Straumann
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
