Subject: |
Re: [makefile] adding a library to an EPICS application |
Ralph Lange <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Thu, 20 Dec 2012 11:00:30 +0100 |
On 20.12.2012 10:37, Pavel Maslov
wrote:
Thanks everyone!
And particularly, MArk and Andrew! Your insights
have helped a lot!
Let me ask you one more question. Perhaps, Andrew
will give a rightaway answer. What makefile command (in
$(TOP)/xxxApp/Db/Makefile) can I use to copy an arbitrary file
(in my case $(TOP)/xxxApp/Db/TDS.proto) to $(TOP)/db.
DB_INSTALLS += TDS.proto doesn't work.
Any other thoughts?
According to the Application Developer's Guide (section 4.7), you
need to specify the full path, i.e.
DB_INSTALLS += $(TOP)/xxxApp/Db/TDS.proto
Did you try that?
~Ralph
- Re: [makefile] adding a library to an EPICS application Pavel Maslov
- [makefile] adding a library to an EPICS application Pavel Maslov
- RE: [makefile] adding a library to an EPICS application Mark Rivers
- Re: [makefile] adding a library to an EPICS application Andrew Johnson
- Re: [makefile] adding a library to an EPICS application Martin Konrad
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
