Hello,
What is the correct way to include a library to an EPICS app? What I've been doing so far: 1. I precompile the library (so I've got an .a or *.so file),
2. Copy the header file into $(TOP)/include/ 3. Then add my library to $(TOP)/helloapp/src/Makefile hello_LIB += my_library 4. cd $(TOP) 5. make 6. Copy libmy_library.so to $(TOP)/lib/$(EPICS_HOST_ARCH)/ 7. Hi! Now, I don't like the process of manually creating these folders, which upon next make uninstall clean will be deleted. What I wanted is to specify the path to libmy_library.so in the RELEASE file, and simply include it in the src/Makefile. As far as I understand, it's neither an EPICS module, nor a support app. Otherwise, it would be pretty much straightforward.
What if my library is installed via make install (header file and *.so are copied to /usr/local/) or is a standard linux lib? Is there a difference if I use shared vs. static lib?
What about the architecture (x86 vs x86_64)? Best regards, Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia Mobile: +7 (951) 672 22 19 Landline: +7 (812) 461 01 01
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
