Thank you all for your replies,
So far I conclude that it is possible to make use of thebeacons to build a
list of the IPs and ports of the existing IOCs.
But then I can only go from IOCs to Records and/or PVs by modifying the code
of all the IOCs (or of the launcher scripts of those IOCs).
This last part is kind of problematic to me since I cannot assume that it will
be done in all facilities. Note that I am not looking for a solution for my
facility (we use Tango) but instead we want to provide a library that can be
used on top of any existing installations elsewhere...
In other words: I don't think I would convince anyone to try out Taurus on
epics if a requirement was to have to modify all the IOCs... ;)
Are there any chances that something like this may end up being part of a base
API in epics?
Cheers,
Carlos
On Mon 17 December 2012 15:35:05 Ralph Lange wrote:
> On 17.12.2012 14:52, [email protected] wrote:
> > One or the other, I've not looked to see what would be involved (well, I
> > have now...). I'd start by thinking of providing a simple socket
> > interface which walks the database, or maybe just returns the results of
> > dbgrep.
> > Actually, a glance at the implementation of dbgrep (src/db/dbTest.c)
> > suggests that the existing code is close to what you need, but needs a
> > tweak (rather than calling puts you'll want more control over where the
> > strings go), but it looks to me as if all the functions called by dbgrep
> > are exported by epics, so writing what you need should be exceptionally
> > easy: just grab a copy of dbgrep, give it a file handle output, replace
> > puts, wrap a socket interface around it, launch it as part of your IOC
> > startup scripts.
> > If it were me, I'd dedicate a socket, read one line from the input, treat
> > it as input to the modified dbgrep, send the results in response, close
> > the socket. Then `echo \* | nc $IOC $PORT` would give you a list of all
> > PVs exported by the IOC.
> > Of course, you'll need to add this code to every IOC...
> You could also create a device support for the waveform record, that (at
> boot time) creates an array (of char) containing all records' names.
> Then a client can simply use CA to get the complete list from an IOC,
> and there is no runtime overhead on the IOC. (Usually the client will be
> faster at doing wildcard matches anyway.)
> ~Ralph
Carlos Pascual Izarra
Scientific Software Coordinator
Computing Division
Cells / Alba Synchrotron [http:/www.cells.es]
Carretera BP 1413 de Cerdanyola-Sant Cugat, Km. 3.3
E-08290 Cerdanyola del Valles (Barcelona), Spain
E-mail: [email protected]
Phone: +34 93 592 4428
- Re: How to get a list of all available PVs Williams Jr., Ernest L.
- Re: How to get a list of all available PVs Andrew Johnson
- Re: How to get a list of all available PVs Tim Mooney
- How to get a list of all available PVs Carlos Pascual
- RE: How to get a list of all available PVs michael.abbott
- Re: How to get a list of all available PVs Ralph Lange
<2012>
<2012>
