1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to get a list of all available PVs
To: [email protected]
Cc: [email protected]
Date: Mon, 17 Dec 2012 13:24:07 +0100
On Mon 17 December 2012 12:38:10 [email protected] wrote:
> From: [email protected] [mailto:tech-talk-
> > If possible I would like to avoid such requirement of manually creating
> > the database.
> > By looking at the CA docs, I see that the IOCs emit periodic beacons,
> > so by listening for at least EPICS_CA_BEACON_PERIOD seconds I should be
> > able to gather a list of active IOCs. Is that right?
> At Diamond I have created a tool which gathers a list of all PVs, but it
> relies on monitoring for CA_PROTO_SEARCH discovery messages, and so will
> only ever gather PVs which have at some time been requested.  Having run
> this tool for a couple of months our database of PVs has grown to 350,000
> entries!
> The purpose of this tool is simply to answer the following question: "when
> a PV goes dead, which IOC was serving it?"  This is intended to be used to
> locate the appropriate IOC to restart when screens in the control room
> start to go dead.
> This monitoring tool sits between the machine network carrying PV traffic
> and our internal database, which itself provides a web interface.  Each
> time a CA_PROTO_SEARCH message is seen for a new PV I add it to an
> internal table and create my own discovery message to locate the serving
> IOC; once found, an update is sent to our database and the PV is
> periodically refreshed.  Updates and retries are carefully throttled to
> avoid generating significant network load.
Very interesting. A similar system but monitoring for CA_PROTO_RSRV_IS_UP
instead of CA_PROTO_SEARCH would work for me provided that then I can get a
list of PVs from a given IOC.
> > And if so, is there a way of interrogating a given IOC for its PVs?
> In principle such a mechanism could be created, but I don't believe it
> exists at present.
What do you mean by "could be created"? Do you mean that Epics could provide
some API to this effect in the future?... Or that a way could be found to do it
with existing APIs? ... or something else?
> To be honest, however, I suspect your requirement is
> back to front -- I don't see that there is a real need for a complete list
> of PVs on a network!
You are probably right in that I am attempting something not useful / needed
by the Epics comunity. The problem may come from my Tango bias. Still, here is
my justification: a typical use case of Taurus is that the user wants to create
a TaurusForm widget [1] to display "Taurus Attributes". These "Taurus
attributes" can be Tango Attributes or, recently, Epics PVs. In the case of
the Tango Attributes, the user can invoke a tree [2] showing all the available
attributes and dynamically add a choice of them to the widget. I just wanted
to provide something similar for PV-based Taurus attributes.
[1] http://www.tango-
controls.org/static/taurus/latest/doc/html/users/ui/forms.html
[2]http://www.tango-
controls.org/static/taurus/latest/doc/html/users/ui/modelchooser.htm
 Carlos Pascual Izarra
 Scientific Software Coordinator
 Computing Division
 Cells / Alba Synchrotron  [http:/www.cells.es]
 Carretera BP 1413 de Cerdanyola-Sant Cugat, Km. 3.3
 E-08290 Cerdanyola del Valles (Barcelona), Spain
 E-mail: [email protected]
 Phone: +34 93 592 4428
RE: How to get a list of all available PVs michael.abbott
How to get a list of all available PVs Carlos Pascual
Re: How to get a list of all available PVs Carlos Pascual
Prev: RE: How to get a list of all available PVs michael.abbott
Next: RE: How to get a list of all available PVs michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
