1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to get a list of all available PVs
To: Pavel Maslov <[email protected]>
Date: Mon, 17 Dec 2012 10:24:56 +0100
Hi Pavel,
Thanks a lot for the quick answer.
Unfortunately what I need is getting the list from a client.
I was hoping that I could somehow broadcast some network message and have all
IOCs or PVs replying...
I understand that both the ssh and the procServ methods would require that the
user running the client has shell access to the box running the IOC (and I
suppose that this is not a general case)
Also, I understand that in general there may be more than one box running
IOCs. Is there any way of discovering them on a local network (e.g., by a port
scan on a certain known port?)
Cheers
On Mon 17 December 2012 09:49:54 Pavel Maslov wrote:
> Hi Carlos,
> on the IOC side issue *dbl* (in the epics shell):
> epics> dbl
> And you'll get all the PVs loaded in to EPICS database.
> If you want to get a list of PVs on the client side though, then I don't
> think that can be implemented as easily as I have descibed above.
> You can always ssh to the IOC box and either execute st.cmd and use the dbl
> command, or use procServ to connect to a running IOC. In this case, I
> suspect the st.cmd file should contain dbl after the iocInit command. As
> for the latter, I have never used procServ myself. So just guessing.
> On Mon, Dec 17, 2012 at 12:38 PM, Carlos Pascual <[email protected]> wrote:
> > Hi,
> > Sorry for this newbie question... I come from the Tango community, and I
> > am quite lost with Epics
> > I am a developer of Taurus [1], a GUI library initially designed to
> > provide PyQT GUIs on top of Tango. But our goal is to also support other
> > communication/control systems such as Epics.
> > I recently implemented some very basic support for epics in Taurus (just
> > a proof of concept) using PyEpics, and one of the first questions that I
> > came across is:
> > How can I obtain a list of all PVs that are available?
> > ... or even better, can I get a list of all PVs whose name contains a
> > certain
> > prefix?
> > The reason I want this is that I want to create a browser/selector of
> > PVs. I
> > do not care that much if the method is slow (I could live with doing it
> > once
> > and only manually refreshing the list).
> > But I need the method to be generic, i.e. it should not assume some non-
> > standard service (such a site-dependent database) to be available.
> > Is this possible at all?
> > Cheers,
> > [1] http://www.tango-controls.org/static/taurus/latest/doc/html/
> >  Carlos Pascual Izarra
> >  Scientific Software Coordinator
> >  Computing Division
> >  Cells / Alba Synchrotron  [http:/www.cells.es]
> >  Carretera BP 1413 de Cerdanyola-Sant Cugat, Km. 3.3
> >  E-08290 Cerdanyola del Valles (Barcelona), Spain
> >  E-mail: [email protected]
> >  Phone: +34 93 592 4428
 Computing Division
How to get a list of all available PVs Carlos Pascual
Re: How to get a list of all available PVs Pavel Maslov
Prev: Re: How to get a list of all available PVs Pavel Maslov
Next: RE: How to get a list of all available PVs ronaldo.mercado
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
