g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re:RE: "Connection refused" when running Ethernet/RS232 application
To: "Mark Rivers" <rivers@cars.uchicago.edu>
Cc: tech-talk <tech-talk@aps.anl.gov>
Date: Thu, 13 Dec 2012 21:48:39 +0800 (CST)
When I use “telnet” from my Linux machine:
  telnet 192.168.0.21 1
I also get connection refused. But “ping 192.168.0.21”, it works well.
I can’t find the “TCP Server Mode” attribute of the port of the NI Ethernet/RS232 convertor(4 ports) , and the port likely needn’t to be configured.
Then, Is the port number the convertor’s port num or the device port in the machine? how should I set the port number in drvAsynIPPortConfigure?
RE: Re:RE: "Connection refused" when running Ethernet/RS232 application Hu, Yong
Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
RE: Re:RE: "Connection refused" when running Ethernet/RS232 application Mark Rivers
"Connection refused" when running Ethernet/RS232 application 张德敏
Prev: Re: .PACT .TIME Pavel Maslov
Next: RE: Re:RE: "Connection refused" when running Ethernet/RS232 application Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: RE: "Connection refused" when running Ethernet/RS232 application Mark Rivers
ANJ, 13 Dec 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
