g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: RE: .PACT .TIME
To: Pavel Maslov <pavel.masloff@gmail.com>, EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Wed, 12 Dec 2012 14:42:18 +0000
What is the record type?
Setting the MDEL to -1 sends the information to the operator - if it is the VAL field.
I should ask - what field do you want to see on the client side?
What client tool are you using?
What device are you talking to?
What driver are you using?
Sent: Wednesday, December 12, 2012 9:35 AM
To: Dalesio, Leo; EPICS Tech Talk
Subject: Re: .PACT .TIME
Leo,
I need an operator (the client) to see if the record has been processed. Your advice works on the IOC side only.
On Wed, Dec 12, 2012 at 5:54 PM, Dalesio, Leo <dalesio@bnl.gov> wrote:
Login and set the TPRO field to a non zero value.
It will print the name of the record and every passive record processed in this lock set after the record with the TPRO field set to 1.
Or, set the deadband of an AI or CALC to -1. It will post the VAL field each time as the absolute value of the change will exceed it.
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Pavel Maslov
Sent: Wednesday, December 12, 2012 8:39 AM
To: EPICS Tech Talk
Subject: .PACT .TIME
Is there a way I can subscribe to these record fields?
I would like to know if my record has been processed.
The record itself is being processed ~30 seconds.
It's strange when I caget record.PACT I can see 1 or 0. However, camonitor doesn't react on the value change whatsoever.
Is there any other way around?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Re: .PACT .TIME Pavel Maslov
Prev: Re: .PACT .TIME Pavel Maslov
Next: Re: .PACT .TIME Rok Šabjan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: Re: .PACT .TIME Pavel Maslov
ANJ, 13 Dec 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
