From 0b5c0803d8facca0693457dfc9aa7296df0543d2 Mon Sep 17 00:00:00 2001
Date: Mon, 10 Dec 2012 16:07:02 -0500
Subject: c++ build fix for gcc 4.7
Storage/ListIndex.cpp | 9 ++++-----
Storage/RTree.cpp | 6 ++++--
Tools/AVLTree.h | 12 +++++++++---
Tools/AVLTreeTest.cpp | 20 ++++++++++++--------
4 files changed, 29 insertions(+), 18 deletions(-)
diff --git a/Storage/ListIndex.cpp b/Storage/ListIndex.cpp
index 6b83635..3d23c37 100644
--- a/Storage/ListIndex.cpp
+++ b/Storage/ListIndex.cpp
@@ -139,11 +139,10 @@ class RTree *ListIndex::getTree(const stdString &channel,
return 0;
-int sort_compare(const stdString &a,
- const stdString &b)
- return b.compare(a);
+template<> struct ItemOps<stdString> {
+ static int compare(const stdString &a, const stdString &b)
+ { return b.compare(a); }
void ListIndex::name_traverser(const stdString &name,
void *self)
diff --git a/Storage/RTree.cpp b/Storage/RTree.cpp
index ebc6aec..4830b45 100644
--- a/Storage/RTree.cpp
+++ b/Storage/RTree.cpp
@@ -409,8 +409,10 @@ bool RTree::selfTest(unsigned long &nodes, unsigned long &records)
// Comparison routine for AVLTree (node_cache)
-int sort_compare(const RTree::Node &a, const RTree::Node &b)
-{ return b.offset - a.offset; }
+template<> struct ItemOps<RTree::Node> {
+ static int compare(const RTree::Node &a, const RTree::Node &b)
+ { return b.offset - a.offset; }
void RTree::read_node(Node &node) const
diff --git a/Tools/AVLTree.h b/Tools/AVLTree.h
index c0a5222..0a1fdbf 100644
--- a/Tools/AVLTree.h
+++ b/Tools/AVLTree.h
@@ -15,6 +15,12 @@
#include <GenericException.h>
#include <AutoFilePtr.h>
+template<class Item>
+struct ItemOps {
+ //static int compare(const Item& a, const Item& b) {return a-b;}
+ //static const char *tostr(const Item &) {return "hi";}
// Tree Item:
// Holds the full Item as well as left/right pointers
template<class Item> class AVLItem
@@ -77,7 +83,7 @@ public:
int comp;
while (n)
- comp = sort_compare(item, n->item);
+ comp = ItemOps<Item>::compare(item, n->item);
if (comp == 0)
item = n->item;
@@ -165,7 +171,7 @@ private:
*node = new_node;
return true;
- int comp = sort_compare(new_node->item, (*node)->item);
+ int comp = ItemOps<Item>::compare(new_node->item, (*node)->item);
if (comp == 0)
{ // Don't insert new node, only update data item
(*node)->item = new_node->item;
@@ -217,7 +223,7 @@ private:
++i;
int me = i;
fprintf(f, "n%d [ label=\"%s (%d)\" ];\n",
- me, toString(node->item), (int)node->balance);
+ me, ItemOps<Item>::tostr(node->item), (int)node->balance);
if (node->left)
fprintf(f, "n%d -> n%d\n", me, i+1);
diff --git a/Tools/AVLTreeTest.cpp b/Tools/AVLTreeTest.cpp
index 4d48933..f423152 100644
--- a/Tools/AVLTreeTest.cpp
+++ b/Tools/AVLTreeTest.cpp
@@ -1,11 +1,10 @@
#include <stdlib.h>
+#include <stdio.h>
#include "AVLTree.h"
#include "UnitTest.h"
-static int sort_compare(const int &a, const int &b)
-{ return b-a; }
static int avl_last_number;
static bool tree_is_ordered;
@@ -17,12 +16,17 @@ static void avl_order_test(const int &i, void *)
avl_last_number = i;
-static const char *toString(const int &i)
- static char txt[10];
- sprintf(txt, "%d", i);
- return txt;
+template<> struct ItemOps<int> {
+ static int compare(const int &a, const int &b)
+ { return b-a; }
+ static const char *tostr(const int &i)
+ static char txt[10];
+ sprintf(txt, "%d", i);
+ return txt;
TEST_CASE avl_test()
1.7.10.4
James Rowland mark.heron
Passive Scanning processing Diego Sanz
<2012>
<2012>
