1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: waveform put in CSS
To: Pavel Maslov <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 4 Dec 2012 19:54:43 +0000
I can't find the email that contained the most recent answer... it said to look at this page:
http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio-3.1/raw-file/tip/applications/plugins/org.csstudio.opibuilder/html/widgets/TextInput.html
Anyway, one can use "Text Update" to display the waveform string, but it is necessary to select format "String" to see the text.  Selecting "Default" will show the elements in ASCII format.
"Text Input" also displays the text, and also gives a choice of "String" or "Default."
Very nice and useful.
Cheers -Mathias
Mathias Steiner
Beam Coordinator
NSCL/Michigan State University
>> Is there a chance I could edit the waveform record in CSS in the same way as using caput...
Re: waveform put in CSS Pavel Maslov
Prev: Re: Using CAJ in production J. Lewis Muir
Next: Initializing starting position on a Motor Tonia Batten
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: waveform put in CSS Chen, Xihui
Next: Re: waveform put in CSS Pavel Maslov
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
