Yes, as Yong mentioned, array is the best way to put data to a waveform. If the waveform is very short, you can also directly put data to the waveform with Text Input widget with the format like “-5000 -4000 -3000 -2000 -1000” See http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio-3.1/raw-file/tip/applications/plugins/org.csstudio.opibuilder/html/widgets/TextInput.html Thanks, Xihui From: Hu, Yong [mailto:[email protected]] Sent: Monday, December 03, 2012 9:13 AM To: 'Pavel Maslov'; EPICS Tech Talk Subject: RE: waveform put in CSS It seems that the Array widget in BOY Version 3.1.1 and higher will do the job although I haven’t tried this feature. See [1] and give a try. Yong [1] http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio-3.1/raw-file/tip/applications/plugins/org.csstudio.opibuilder/html/ChangeLog.html#3.1.1 Hello, guys Is there a chance I could edit the waveform record in CSS in the same way as using caput with the "-a" parameter: caput -a agilent1:userWF 5 -5000 -4000 -3000 -2000 -1000 I can get a waveform using the XY Graph or Text Update widgets. However, if I want to put data in the record, it doesn't work for me. Any ideas?
-- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia
Mobile: +7 (951) 672 22 19 Landline: +7 (812) 461 01 01 |
- waveform put in CSS Pavel Maslov
- RE: waveform put in CSS Hu, Yong
Re: Missing symbol cannel archiver Kasemir, Kay
Re: Using CAJ in production Andrew Johnson
<2012>
RE: waveform put in CSS Steiner, Mathias
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
