1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS Base 3.14.12.3-rc1 available for testing
To: "EPICS tech-talk" <[email protected]>
Date: Mon, 3 Dec 2012 17:40:47 -0600
The first release candidate for the 3.14.12.3 version of Base is now available
on the EPICS website for general testing.  Links to the tarfile and Release
Notes can be found at http://www.aps.anl.gov/epics/base/R3-14/12.php
The Release Notes list the changes since the 3.14.12.2 release, which are
mostly bug-fixes and build system updates of various kinds.  All previously
documented Known Problems have been fixed in this release, except for the
MaxOS-X issue documented on 2012-01-04 concerning compilation of the Perl CA
library, for which a workaround is given in the Known Problems document on the
website.
Please report any problems you find to tech-talk.  If no major issues are
discovered before December 17th we will release 3.14.12.3 on that date.
Thanks to everyone who has helped test pre-release versions.
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
Prev: RE: caRepeater object code not cross-compiled in R3.14.12.2 Hill, Jeff
Next: Re: Using CAJ in production J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Job opening at PSI Dirk Zimoch
Next: Missing symbol cannel archiver James F Ross
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
