g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: Using CSS and setting up RDB Archiver
To: James F Ross <james.falconer.ross@gmail.com>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Mon, 3 Dec 2012 16:15:16 -0500
Hi:
>From:  James F Ross <james.falconer.ross@gmail.com
>With the exception of org.csstudio.archive.rdb, these are all imported
>from SNS snapshot 3.0.2 rather than 3.1.2, so that may be part of it.
I assume that's the issue.
What version of the IDE are you using, or more to the point: What's the
target platform in case you're not using the IDE as the target platform?
When you're using Eclipse 3.7.2 and the SNS 3.1.2 source snapshot, you
should be fine.
With other combinations,
>Is there a good way to find out what errors CSS is sensing in these
>plugins?  Or will I have to go through each error and find any other
>missing plugins?
Yes, fundamentally you have to look for each error and figure it out.
-Kay
On Mon, Dec 3, 2012 at 9:39 AM, Kasemir, Kay
<kasemirk@ornl.gov> wrote:
You need to use a version of Eclipse that matches the version of the
source code.
The SNS source snapshot for CSS 3.1.2 for example,
https://ics-web.sns.ornl.gov/css/products.html, supports Eclipse 3.7.2 as
a target platform.
If you have different sources or a different target platform, you can try
to resolve the plugin dependencies as described in  Fix Dependencies on
http://cs-studio.sourceforge.net/docbook/ch15.html, but that is tedious.
Overall it's best to start with a matching set of sources and Eclipse IDE.
Re: Using CSS and setting up RDB Archiver James F Ross
Prev: Re: Using CSS and setting up RDB Archiver James F Ross
Next: RE: caRepeater object code not cross-compiled in R3.14.12.2 Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: Tektronix 3014 IOC Errors Trevor Downer
ANJ, 03 Dec 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
