Hi:
The details of which eclipse plugin provides jetty and its dependencies
have changed with most eclipse releases.
You need to use a version of Eclipse that matches the version of the
source code.
The SNS source snapshot for CSS 3.1.2 for example,
https://ics-web.sns.ornl.gov/css/products.html, supports Eclipse 3.7.2 as
a target platform.
If you have different sources or a different target platform, you can try
to resolve the plugin dependencies as described in Fix Dependencies on
http://cs-studio.sourceforge.net/docbook/ch15.html, but that is tedious.
Overall it's best to start with a matching set of sources and Eclipse IDE.
Kay
Date: Friday, November 30, 2012 14:11
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Subject: Re: Using CSS and setting up RDB Archiver
I seem to be missing some necessary files for the RDB archiver to run
properly. I get the following errors when trying to run
org.csstudio.archiver.engine/ArchiveEngine.product (see below). I found
org.eclipse.equinox.http.jetty8 ...
- Re: Using CSS and setting up RDB Archiver James F Ross
RE: waveform put in CSS Hu, Yong
Re: Using CAJ in production J. Lewis Muir
<2012>
<2012>
