It seems that the Array widget in BOY Version 3.1.1 and higher will do the job although I haven’t tried this feature. See [1] and give a try.
Yong
[1]
http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio-3.1/raw-file/tip/applications/plugins/org.csstudio.opibuilder/html/ChangeLog.html#3.1.1
Hello, guys
Is there a chance I could edit the waveform record in CSS in the same way as using caput with the "-a" parameter:
caput -a agilent1:userWF 5 -5000 -4000 -3000 -2000 -1000
I can get a waveform using the XY Graph or Text Update widgets. However, if I want to put data in the record, it doesn't work for me.
Any ideas?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
- RE: waveform put in CSS Chen, Xihui
- waveform put in CSS Pavel Maslov
Job opening at PSI Dirk Zimoch
Re: Using CSS and setting up RDB Archiver Kasemir, Kay
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
