g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: Agilent N1912A
To: "Szalata, Zenon M." <zms@slac.stanford.edu>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 28 Nov 2012 15:39:50 -0600
Zen,
I just created support for the N1914A, which can be used with either LAN or GPIB. I would suspect that most of it will work for you, just delete support for channel C & D in the database.
If interested I will package it up for you and send it to you to try. I'm still working on it, but most of it is working fine for me, but you might come across an issue.
Nick D.
On 11/28/2012 2:37 PM, Szalata, Zenon M. wrote:
Hello All,
I wonder if anyone has written software for this device.  I want to use the Ethernet interface that the device is equipped with.
I started writing an asynPortDriver class support for it and I am running into all kind of difficulties.  Many perfectly good commands put the device in a strange state, where the remote interface in it seems to go dead.
I found a Note in the programmer manual which says:
When TRIG:SOUR is INT1, INT2 or EXT and a new acquisition has been initiated (using the
INIT command for example), FETCH? waits until the trigger takes place before executing. If trigger
conditions are not satisfied - when the trigger level differs greatly from the signal level for example -
this can give the impression that the power meter has hung.
To unlock the power meter and adjust trigger settings, an SDC (Selected Device Clear) GPIB
Command must be performed. This is equivalent to “EXECUTE CLEAR” in Agilent VEE.
Which is probably what is getting me.  The only way I can get the instrument out of this is to power cycle it.
Zen
Agilent N1912A Szalata, Zenon M.
Prev: Agilent N1912A Szalata, Zenon M.
Next: Re: Data acquisition for ICP accelerometers Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: problems instaling edm with scientific linux 5.2 Qazi Zia-ul-Haque
ANJ, 29 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
