Hi Till,
You have convinced me that dropping SCHED_FIFO should not be a problem, so all
that remains is to get a portable implementation of the fix.
On 2012-11-27 Till Straumann wrote:
> On 11/27/2012 03:18 PM, Andrew Johnson wrote:
> > If the child process of the fork() were to
> > change to SCHED_OTHER before calling execlp() the new program might not
> > have the privilege necessary to switch back — is that correct?
> IIRC this is not correct: resource limits are preserved across fork and
> exec.
> Hence, if the parent is able to use an RT priority so is the child. This
> feature,
> BTW, allows you e.g., to set the soft limit for RTPRIO from the shell which
> executes a IOC process (provided that the sysadmin has given your shell a
> high enough hard limit).
Ok, so you're saying the exec'd program would be able to switch back to
SCHED_FIFO if it needs to; that's the main thing I was worrying about.
> > Personally I would solve the problem of having an RT-scheduled caRepeater
> > by ensuring that caRepeater always gets started when the system comes up
> > before the IOCs get run, say from an /etc/init.d script.
> Of course, that was my first thought, too. However, what happens if
> this caRepeater for some reason dies - wouldn't the RT-IOC try to
> spawn a new one (now running under SCHED_FIFO)? This could lead
> to ugly spurious real-time violations.
True, unless we had some kind of wrapper that would restart the caRepeater.
However fixing osiSpawnDetachedProcess() as you suggest would be a simpler
solution.
Do you have an implementation of the fix that is portable to all our Posix
targets? If I get one this week I might be able to get into 3.14.12.3.
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
- Re: posix osiSpawnDetachedProcess inherits scheduling policy + priority Ralph Lange
- posix osiSpawnDetachedProcess inherits scheduling policy + priority Till Straumann
- Re: posix osiSpawnDetachedProcess inherits scheduling policy + priority Andrew Johnson
- Re: posix osiSpawnDetachedProcess inherits scheduling policy + priority Till Straumann
Re: Data acquisition for ICP accelerometers S. Stein
<2012>
<2012>
