1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Data acquisition for ICP accelerometers
To: <[email protected]>, <[email protected]>
Date: Wed, 28 Nov 2012 10:50:23 +0000
This probably doesn't meet your requirements, but thought I'd mention it...
On at least one beamline at DLS we have a few Bruel & Kjaer charge accelerometers mounted inside a UHV double crystal monochromator. We use their Nexus amplifier to read the signals and feed them into a 16-bit ADC, and we control the amplifier via RS232. Then we do a FFT on the amplifier waveform data. But we only have a few channels to deal with, and we don't actively monitor the data (just analyse it on a ah-hoc basis when we have time).
However, we've only just started to use them so we don't have much experience with them so far. I'm not sure which actual accelerometer we're using, but the manufacturer has a range of different types. We use them for looking for mechanical vibrations in the 1-100Hz range.
http://www.bksv.com/products/transducers/conditioning/charge/2692c.aspx?JsEnabled=0
Emma Shepherd developed the streams based Epics support for the amplifier.
Cheers,
Matt
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Matt Rippa
> Sent: 28 November 2012 02:39
> To: [email protected]
> Subject: Data acquisition for ICP accelerometers
> Hi,
> Has anyone worked with vibration monitoring and analysis in
> EPICS? We're looking for a digitizing system with 24 or more
> channels and dynamic range of 96 dB or higher. Our sensors are
> ICP accelerometers with resolution down to 50 ug's (uV) and
> sensitivity of 1V/g.
> It seems there are plenty of 'turn-key' systems out there with
> Windows only. For example, this is a good fit but no linux/epics.
> http://www.spectraldynamics.com/index.php/products/puma
> Thanks,
> -Matt
Re: Data acquisition for ICP accelerometers S. Stein
Data acquisition for ICP accelerometers Matt Rippa
Prev: Re: posix osiSpawnDetachedProcess inherits scheduling policy + priority Till Straumann
Next: Re: Data acquisition for ICP accelerometers S. Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Data acquisition for ICP accelerometers Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
