Hi Jack,
On 2012-11-27 Jack Smith wrote:
> According to EPICS R3.14 Channel Access Reference Manual [1], I think
> caRepeater is only needed when multiple CA clients (CSS, EDM, etc.)
> run on the same host. Why should multiple IOC applications on the same
> Linux host be using caRepeater?
An IOC is a CA client as well as being a server: record links often point to
records on other IOCs, the Access Security mechanism may subscribe to channels
on other servers, and any sequence programs running in the IOC also use CA.
The caRepeater is looked for and if necessary started at iocInit even if the
CA client library never actually has to make any external connections because
all of the PV names requested can be found locally within the IOC.
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
- Re: caRepeater object code not cross-compiled in R3.14.12.2 Jack Smith
- caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Re: posix osiSpawnDetachedProcess inherits scheduling policy + priority Andrew Johnson
<2012>
<2012>
