g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: caRepeater object code not cross-compiled in R3.14.12.2
Cc: EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Thu, 22 Nov 2012 09:39:13 +0100
Hello Rod,
In src/ca/Makefile, you find caRepeater in PROD_HOST. Thus it is not made for cross builds. Try to take it out and instead set
PROD_DEFAULT = caRepeater
PROD_vxWorks = -nil-
This should build the caRepeater for all non-vxWorks architectures, not only for the host architecture.
Dirk
On 21.11.2012 18:57, Rod Nussbaumer wrote:
Hi all.
Did I do something wrong?
My $EPICS_HOST_ARCH is linux-x86. I've added to
configure/os/CONFIG_SITE.linux-x86.Common the line:
CROSS_COMPILER_TARGET_ARCHS = linux-arm
In configure/os/CONFIG_SITE.linux-x86.linux-arm, I've set $GNU_DIR&
$GNU_TARGET to identify the name and location of my cross toolchain.
The build completes normally, and in bin/linux-arm I see a small number
of channel access tools, as well as a script to launch caRepeater, but
no caRepeater binaries. The tools built for the cross-compiled
architecture seem to work normally. My target architecture is a full-on
Linux host, which may run multiple IOC applications, and should be using
caRepeater.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Re: caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Prev: Re: 3.14 v.s. 3.15 vs. v4 Pete Jemian
Next: Get a time difference in EPICS database 洪春霞
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Next: Re: caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
