g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: channel archiver on 64 bit? Re: archive data server
To: tech-talk@aps.anl.gov
Date: Mon, 19 Nov 2012 16:20:17 -0500
I had a look and don't think we have any 64-bit specific changes. Aside from a few build fixes (mostly missing headers) all changes are to the management scripts.
However, we build against possibly different versions of the library dependences. With the exception of xmlrpc-c we use the versions from the official debian Squeeze (6.0) repository. A newer version of xmlrpc-c is needed to get proper support for tiny floating point values (eg. vacuum pressures).
Versions of the relevant dependencies which we use:
xerces-c  2.8.0+deb1-2+b1
xmlrpc-c  1.16.33-3~bpo60+2
Direct links to source
http://epics.nsls2.bnl.gov/debian/pool/main/c/channelarchiver/channelarchiver_2.9.2+dfsg.orig.tar.gz
http://epics.nsls2.bnl.gov/debian/pool/main/c/channelarchiver/channelarchiver_2.9.2+dfsg-11.1.diff.gz
If you want to see all the gory details:
git clone http://pubweb.bnl.gov/~mdavidsaver/git/dpack/channelarchiver.git
On 11/19/2012 11:42 AM, Ralph Lange wrote:
James,
The Debian packages by Michael Davidsaver are available for 32 and 64
bit Intel architectures.
Naturally, the source packages, that these binary packages are compiled
from, do compile on 32 and 64 bit.
Both are available from the BNL repository at
~Ralph
On 19.11.2012 16:43, John William Sinclair wrote:
James,
I built the archiver for a 64bit cpu and had to make quite a few changes.
For XML support, I have only updated the Xerces code so if you are
using something else you may have other issues.
I have attached an archive of all files (only in the message sent
specifically to James).
Best,
John Sinclair
On 11/19/2012 10:33 AM, James F Ross wrote:
I haven't been working on any updates...  I'm just trying to get all
aspects of the channel archiver to run, which it is doing for the
most part.  It is just the data server that I'm having trouble with.
For the moment, I'm just trying to find out why there is an undefined
symbol in the library libxmlrcp_cgi.so.3 when I try to run
ArchiveDataServer.cgi.  The complete error message is:
[Mon Nov 19 09:36:24 2012] [error] [client 127.0.0.1]
/var/www/html/archive/cgi/ArchiveDataServer.cgi: symbol lookup error:
/usr/local/lib/libxmlrpc_cgi.so.3: undefined symbol: xmlrpc_registry_new
[Mon Nov 19 09:36:24 2012] [error] [client 127.0.0.1] Premature end
of script headers: ArchiveDataServer.cgi
Thanks!
James
On Mon, Nov 19, 2012 at 10:29 AM, Kasemir, Kay<kasemirk@ornl.gov
<mailto:kasemirk@ornl.gov>>  wrote:
     Hello:
     >  The archiver won't compile on 64 bit…
     I believe there are sites who updated the sources to compile on 64
     bit.
     In 2010, the channel archiver sources have been moved from an SNS
     repository to source forge so that other sites can easily
     contribute such updates.
     If you have been working on 64 bit updates and need write access
     to the SF repo, please let me know.
     Or if  you prefer to publish your updates by other means, please
     contact Andrew so he can list that on the EPICS extensions web site.
     Kay
<mailto:james.falconer.ross@gmail.com><mailto:james.falconer.ross@gmail.com
     <mailto:james.falconer.ross@gmail.com>>>
     Date: Monday, November 19, 2012 09:56
     To: Kasemir Kay<kasemirk@ornl.gov
     <mailto:kasemirk@ornl.gov><mailto:kasemirk@ornl.gov
     <mailto:kasemirk@ornl.gov>>>
     Cc: "tech-talk@aps.anl.gov
     <mailto:tech-talk@aps.anl.gov><mailto:tech-talk@aps.anl.gov
     <mailto:tech-talk@aps.anl.gov>>"<tech-talk@aps.anl.gov
     <mailto:tech-talk@aps.anl.gov>>>
     Subject: Re: archive data server
     I should add that the ldd command indicates that I have the right
     library file from the old computer.
     James
     On Mon, Nov 19, 2012 at 9:44 AM, James F Ross
     <james.falconer.ross@gmail.com
     <mailto:james.falconer.ross@gmail.com>>>  wrote:
     Ok, I've found all of the libraries that ArchiveDataServer.cgi
     calls, but I'm having an issue with one of them.  As mentioned
     before, I've had to transfer the channel archiver to a new
     machine.  The difficulty is that the new machine is 64 bit linux
     while the old one is 32 bit.  The archiver won't compile on 64
     bit, so it was compiled on 32 bit linux and transfered.  For the
     most part, it is working, save for ArchiveDataServer.cgi
     I've transferred the libraries that are needed by
     ArchiveDataServer.cgi, but I'm getting an error with one of them.
      Any help with getting past this would be most welcome.
     The error:
     error: /usr/local/lib/libxmlrpc_cgi.so.3: undefined symbol:
     xmlrpc_registry_new
     end of script headers: ArchiveDataServer.cgi
     Thanks very much!
     James Ross
     On Thu, Nov 15, 2012 at 10:21 AM, James F Ross
     Hello everyone
     Ok, I found out what the problem was.  ArchiveDataServer.cgi is
     failing to find some library files that it needs.  This is
     probably because this is a new computer and things aren't
     completely set up the way they were on the old machine running the
     archiver.  I'm in the process of tracking down the libraries it is
     complaining about and making links to them in /usr/lib and
     /usr/local/lib which seems to be working.
     Thanks for all the help!  I'll ask if I have further questions
     James
     On Tue, Nov 13, 2012 at 10:52 AM, Kasemir, Kay<kasemirk@ornl.gov
     <mailto:kasemirk@ornl.gov>>>  wrote:
     Hi James:
     >my current issue seems to be that the archive data server is not
     working.
     Correct, that's what this means:
     >"java.lang.IllegalArgumentException: Couldn't execute the
     archiver.info
     <http://archiver.info><http://archiver.info><http://archiver.info>
     request java.io.IOException: Unexpected Response from Server:
      Internal Server Error"
     The old archive manual,
     https://ics-web.sns.ornl.gov/kasemir/archiver/manual.pdf, has
     sections about the setup and testing of the ArchiveDataServer.cgi
     (4.3.1, 4.3.3, ..).
     You can try to connect to the ArchiveDataServer.cgi via "telnet"
     to see if the web server is executing it at all.
     If it's running, it will also update a file /tmp/archserver.log
     (something like that, don't remember the exact name in /tmp) with
     the recent requests. If the archiver.info
     <http://archiver.info><http://archiver.info>  request already
     fails, that should indicate that the ArchiveDataServer.cgi is
     really not invoked at all. Your web server might return the binary
     bits of the ArchiveDataServer.cgi file instead of executing it.
     -Kay
Re: archive data server James F Ross
channel archiver on 64 bit? Re: archive data server Kasemir, Kay
Re: channel archiver on 64 bit? Re: archive data server James F Ross
Re: channel archiver on 64 bit? Re: archive data server John William Sinclair
Re: channel archiver on 64 bit? Re: archive data server Ralph Lange
Prev: Re: EPICS on SL6.x Andrew Johnson
Next: RE: asynPortDriver epicsMutex error Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: channel archiver on 64 bit? Re: archive data server Ralph Lange
Next: StreamDevice and sCalcoutRecord.h Pavel Maslov
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
