On 15.11.2012 15:33, Martin L. Smith wrote:
When using steamDevice exception handlers and in particular the
replytimeout and readtimeout handlers, what would one normally
do in these handlers?
Probably send something to the device to reset it. Not much that would
help EPICS. I once used it to change the baud rate because the device
always started with a slow baud rate after power on.
For a mismatch I simply get whatever the received data was and put
that in a string record for display so that I know that something
went wrong ... since the error messages are now suppressed from this
error.
Are they? They should be suppressed for "I/O Intr" records only. I will
check. A mismatch handler allows you to re-parse the input. But the
other handlers don't.
Is it possible to set a PV to a value without using an "in" command?
Or would I simply look at the STAT field of the record using the protocol
to know that something happened in the case of a timeout error?
Unfortunately I have no way (so far) to set PVs to some constant value.
but perhaps....: in "%#{=17}"; would probably set the value 17
independently on the input, but only if there is any input.
Dirk
Marty
- streamDevice Exception Handler Question Martin L. Smith
Re: channel archiver on 64 bit? Re: archive data server Ralph Lange
Re: EPICS on SL6.x Andrew Johnson
<2012>
DB Question Szalata, Zenon M.
<2012>
