g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: channel archiver on 64 bit? Re: archive data server
To: tech-talk@aps.anl.gov
Date: Mon, 19 Nov 2012 10:43:26 -0500
James,
I built the archiver for a 64bit cpu and had to make quite a few changes.
For XML support, I have only updated the Xerces code so if you are using something else you may have other issues.
I have attached an archive of all files (only in the message sent specifically to James).
Best,
John Sinclair
On 11/19/2012 10:33 AM, James F Ross wrote:
I haven't been working on any updates... I'm just trying to get all aspects of the channel archiver to run, which it is doing for the most part. It is just the data server that I'm having trouble with.
For the moment, I'm just trying to find out why there is an undefined symbol in the library libxmlrcp_cgi.so.3 when I try to run ArchiveDataServer.cgi. The complete error message is:
[Mon Nov 19 09:36:24 2012] [error] [client 127.0.0.1] /var/www/html/archive/cgi/ArchiveDataServer.cgi: symbol lookup error: /usr/local/lib/libxmlrpc_cgi.so.3: undefined symbol: xmlrpc_registry_new [Mon Nov 19 09:36:24 2012] [error] [client 127.0.0.1] Premature end of script headers: ArchiveDataServer.cgi
Thanks!
James
On Mon, Nov 19, 2012 at 10:29 AM, Kasemir, Kay <kasemirk@ornl.gov <mailto:kasemirk@ornl.gov>> wrote:
    Hello:
    > The archiver won't compile on 64 bit…
    I believe there are sites who updated the sources to compile on 64
    bit.
    In 2010, the channel archiver sources have been moved from an SNS
    repository to source forge so that other sites can easily
    contribute such updates.
    If you have been working on 64 bit updates and need write access
    to the SF repo, please let me know.
    Or if  you prefer to publish your updates by other means, please
    contact Andrew so he can list that on the EPICS extensions web site.
    Kay
    <mailto:james.falconer.ross@gmail.com><mailto:james.falconer.ross@gmail.com
    <mailto:james.falconer.ross@gmail.com>>>
    Date: Monday, November 19, 2012 09:56
    To: Kasemir Kay <kasemirk@ornl.gov
    <mailto:kasemirk@ornl.gov><mailto:kasemirk@ornl.gov
    <mailto:kasemirk@ornl.gov>>>
    Cc: "tech-talk@aps.anl.gov
    <mailto:tech-talk@aps.anl.gov><mailto:tech-talk@aps.anl.gov
    <mailto:tech-talk@aps.anl.gov>>" <tech-talk@aps.anl.gov
    <mailto:tech-talk@aps.anl.gov>>>
    Subject: Re: archive data server
    I should add that the ldd command indicates that I have the right
    library file from the old computer.
    James
    On Mon, Nov 19, 2012 at 9:44 AM, James F Ross
    <james.falconer.ross@gmail.com
    <mailto:james.falconer.ross@gmail.com>>> wrote:
    Ok, I've found all of the libraries that ArchiveDataServer.cgi
    calls, but I'm having an issue with one of them.  As mentioned
    before, I've had to transfer the channel archiver to a new
    machine.  The difficulty is that the new machine is 64 bit linux
    while the old one is 32 bit.  The archiver won't compile on 64
    bit, so it was compiled on 32 bit linux and transfered.  For the
    most part, it is working, save for ArchiveDataServer.cgi
    I've transferred the libraries that are needed by
    ArchiveDataServer.cgi, but I'm getting an error with one of them.
     Any help with getting past this would be most welcome.
    The error:
    xmlrpc_registry_new
    Thanks very much!
    James Ross
    On Thu, Nov 15, 2012 at 10:21 AM, James F Ross
    Hello everyone
    Ok, I found out what the problem was.  ArchiveDataServer.cgi is
    failing to find some library files that it needs.  This is
    probably because this is a new computer and things aren't
    completely set up the way they were on the old machine running the
    archiver.  I'm in the process of tracking down the libraries it is
    complaining about and making links to them in /usr/lib and
    /usr/local/lib which seems to be working.
    Thanks for all the help!  I'll ask if I have further questions
    James
    On Tue, Nov 13, 2012 at 10:52 AM, Kasemir, Kay <kasemirk@ornl.gov
    <mailto:kasemirk@ornl.gov>>> wrote:
    Hi James:
    >my current issue seems to be that the archive data server is not
    working.
    Correct, that's what this means:
    >"java.lang.IllegalArgumentException: Couldn't execute the
    archiver.info
    <http://archiver.info><http://archiver.info><http://archiver.info>
    request java.io.IOException: Unexpected Response from Server:
     Internal Server Error"
    The old archive manual,
    https://ics-web.sns.ornl.gov/kasemir/archiver/manual.pdf, has
    sections about the setup and testing of the ArchiveDataServer.cgi
    (4.3.1, 4.3.3, ..).
    You can try to connect to the ArchiveDataServer.cgi via "telnet"
    to see if the web server is executing it at all.
    If it's running, it will also update a file /tmp/archserver.log
    (something like that, don't remember the exact name in /tmp) with
    the recent requests. If the archiver.info
    <http://archiver.info><http://archiver.info> request already
    fails, that should indicate that the ArchiveDataServer.cgi is
    really not invoked at all. Your web server might return the binary
    bits of the ArchiveDataServer.cgi file instead of executing it.
    -Kay
Re: channel archiver on 64 bit? Re: archive data server Ralph Lange
Re: archive data server James F Ross
channel archiver on 64 bit? Re: archive data server Kasemir, Kay
Re: channel archiver on 64 bit? Re: archive data server James F Ross
Prev: Re: channel archiver on 64 bit? Re: archive data server James F Ross
Next: Re: channel archiver on 64 bit? Re: archive data server Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
