1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: StreamDevice and sCalcoutRecord.h
To: [email protected]
Date: Thu, 15 Nov 2012 16:48:41 +0100
On 15.11.2012 11:12, Pavel Maslov wrote:
When I try to compile StreamDevice (ASYN 4-16, base 3.14.12,
StreamDevice 2-4, 2-5), I get the following error. What's wrong? Any ideas?
//usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux
  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -MMD -I.
-I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include
  -I/home/operator/applications/epics/modules/asyn/include
-I/home/operator/applications/epics/base/include/os/Linux
../devscalcoutStream.c/
/../devscalcoutStream.c:21:28: warning: sCalcoutRecord.h: No such file
or directory/
Hello Pavel,
sCalcout is an optional record from SynApps. If you don't have SynApps installed, you can skip the whole srcSynApps subtree of StreamDevice.
I thought that I had a mechanism in the srcSynApps/Makefile that compiles the stuff only if SynApps is installed, but maybe there is something wrong there. I will check this.
Dirk
Re: StreamDevice and sCalcoutRecord.h Dirk Zimoch
StreamDevice and sCalcoutRecord.h Pavel Maslov
Prev: Re: archive data server James F Ross
Next: Re: Long string support in CA clients and device support J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: StreamDevice and sCalcoutRecord.h Tim Mooney
Next: Re: StreamDevice and sCalcoutRecord.h Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
