Hello everyone Ok, I found out what the problem was. ArchiveDataServer.cgi is failing to find some library files that it needs. This is probably because this is a new computer and things aren't completely set up the way they were on the old machine running the archiver. I'm in the process of tracking down the libraries it is complaining about and making links to them in /usr/lib and /usr/local/lib which seems to be working.
Thanks for all the help! I'll ask if I have further questions James
On Tue, Nov 13, 2012 at 10:52 AM, Kasemir, Kay <[email protected]> wrote:
Hi James:
>my current issue seems to be that the archive data server is not working.
Correct, that's what this means:
>"java.lang.IllegalArgumentException: Couldn't execute the archiver.info<http://archiver.info> request java.io.IOException: Unexpected Response from Server: Internal Server Error"
The old archive manual, https://ics-web.sns.ornl.gov/kasemir/archiver/manual.pdf, has sections about the setup and testing of the ArchiveDataServer.cgi (4.3.1, 4.3.3, ..).
You can try to connect to the ArchiveDataServer.cgi via "telnet" to see if the web server is executing it at all.
If it's running, it will also update a file /tmp/archserver.log (something like that, don't remember the exact name in /tmp) with the recent requests. If the archiver.info request already fails, that should indicate that the ArchiveDataServer.cgi is really not invoked at all. Your web server might return the binary bits of the ArchiveDataServer.cgi file instead of executing it.
-Kay
- Re: archive data server James F Ross
- archive data server James F Ross
- Re: archive data server Kasemir, Kay
Re: StreamDevice and sCalcoutRecord.h Tim Mooney
Re: StreamDevice and sCalcoutRecord.h Dirk Zimoch
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
