1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problems sending \x0 with devGpib driver
To: Eric Norum <[email protected]>
Cc: [email protected], Andrew Wagner <[email protected]>
Date: Thu, 08 Nov 2012 14:50:48 +0100
On 08.11.2012 05:56, Eric Norum wrote:
The convert routine is passed the parameters from the command table entry and if it wants it can get at a pointer to the entire command table entry so you can likely provide a single routine that will handle lots of table entries.  You might be able to get away with having to write only a single convert routine for all the commands you need to send.
Certainly a pain, though.
I wonder if StreamDevice would work.
Yes.
The problem is writeMsgString(gpibDpvt *pgpibDpvt,const char *str) from devGpib/devSupportGpib.c which does not have any length parameter.
The lower level asynOctet function write() as well as all implementations I have seen have (and use) a length parameter. StreamDevice uses this function and passes the correct length.
Do not use devGpib for any new project!
On Nov 7, 2012, at 8:49 PM, Andrew Wagner<[email protected]>  wrote:
Hey Eric,
Thanks for the advice and commiserating. I already wrote a standalone C++ program to communicate with this thing and it took a little while to write the functions to append and strip \x0\x7 on/off of every string I sent/received from it. It really amazed me that they chose to start every command with \x0 since thats what the entire rest of the world has agreed means end of string. I was hoping to avoid having to write my own version of AsynIPPort just to deal with the \x0\x7 bytes.
Cheers,
Andrew
Re: Problems sending \x0 with devGpib driver Dirk Zimoch
Re: Problems sending \x0 with devGpib driver Nicholas P. DiMonte
Re: Problems sending \x0 with devGpib driver Eric Norum
Problems sending \x0 with devGpib driver Andrew Wagner
Re: Problems sending \x0 with devGpib driver Andrew Wagner
Prev: EPICS Collaboration Meeting October 2012 : Update Ilyou Kim
Next: Re: Problems sending \x0 with devGpib driver Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problems sending \x0 with devGpib driver Eric Norum
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
