g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Problems sending \x0 with devGpib driver
To: tech-talk@aps.anl.gov
Date: Wed, 7 Nov 2012 19:57:18 -0800
Hey everyone,
I'm having trouble sending a byte array via an asyn devGpib driver I'm writing for an STM23S-2EE Applied Motion Products. The problem occurs when I define:
static struct gpibCmd gpibCmds[] = {
   /* Param 0 - On-chip temperature in deg C*/
   {&DSET_AI, GPIBREAD, IB_Q_HIGH, "\x0\x07\x49\x54\x30", NULL, 0, 100, readTemp, 0, 0, NULL, NULL, NULL}
and process the linked record:
epics> write 1
0d
I only write a single byte (in this case the appropriate eos character \r) If I try to send the message with an asynOctet I get the desired result:
asynOctetWriteRead("test","\x0\x7\x49\x54\x30",10)
epics> write 6
00 07 49 54 30 0d
epics> read 9
00 07 49 54 3d 35 34 37 0d
(I'm formatting the debug messages to print hex in case you're curious) Its clear that the command char* defined in the gpibCmd struct is being recast or formatted somehow outside of my driver and that when this occurs the \x0 is interpreted as an end of character array so no message is written. AsynOctet however interprets the char* as literal bytes. I would be very grateful if some has experience with Applied Motion products drivers or using devGpib to send byte arrays. I've had a lot of luck in the past using the devGpib template to write drivers and this is the first time I've had trouble with it actually sending what I wanted.
Cheers,
Andrew
Andrew Wagner
Postdoctoral Researcher
Department of Physics
University of Washington
apwagner@uw.edu
Re: Problems sending \x0 with devGpib driver Eric Norum
Prev: Profinet John William Sinclair
Next: Re: Problems sending \x0 with devGpib driver Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
