g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: How to debug an IOC running on MSWindows using windbg
To: <tech-talk@aps.anl.gov>
Date: Wed, 31 Oct 2012 15:53:29 +0000
The following is a list of instructions to allow debugging of an EPICS IOC on Windows using the Microsoft Windows Debugger (WinDbg).
I have little development experience of EPICS but medium experience of windbg. On hearing that people were experiencing problems debugging iocs on Windows I
decided to check it out.
Brief Introduction to Windows Debugger and comparison with Visual Studio
WinDbg provides a user interface to the underlying debugging engine called Windows Debugger which is implemented in dbgeng.dll. Other interfaces to this engine exist which collectively are called Windows Debuggers. Note that the Visual Studio debugger is completely different to the Windows debugger; however it is possible to integrate use of the Windows Debugger within Visual Studio in Windows 7 and later.
For more information see the documentation in the Windows SDK.
Brief Introduction to winDbg
Microsoft Windows Debugger (WinDbg) is a powerful Windows-based debugger that is capable of both user-mode and kernel-mode debugging. WinDbg provides debugging for the Windows kernel, kernel-mode drivers, and system services, as well as user-mode applications and drivers.
WinDbg uses the Visual Studio debug symbol formats for source-level debugging. It can access any symbol or variable from a module that has PDB symbol files, and can access any public function's name that is exposed by modules that were compiled with COFF symbol files (such as Windows .dbg files). WinDbg can view source code, set breakpoints, view variables (including C++ objects), stack traces, and memory. Its Debugger Command window allows the user to issue a wide variety of commands. For kernel-mode debugging, WinDbg typically requires two computers (the host computer and the target computer). WinDbg also supports various remote debugging options for both user-mode and kernel-mode targets.
WinDbg is a graphical-interface counterpart to CDB/NTSD and to KD/NTKD.
Building EPICS base, an IOC and symbol files
1. Download and build EPICS base.
Simply follow the existing instructions on the ANL EPICS Windows page( http://www.aps.anl.gov/epics/base/win32.php), including the additional instructions
posted by Carsten Winkler.(http://www.aps.anl.gov/epics/tech-talk/2010/msg00595.php)
I choose to use:
Visual C++ 2010 Express
7zip
ActivePerl
GnuWin 3.8.1
Note that I set EPICS_HOST_ARCH=win32-x86 although the OS is Windows 64bit.
2. Build the example ioc
a)Follow the instructions in the Application Developer Guide section 2.2.2 (http://windbg.info/download/doc/pdf/WinDbg_A_to_Z_color.pdf)
mkdir c:\ioc1
cd c:\ioc1
c:\base-3.14.12\bin\win32-x86\makeBaseApp.pl -t example myexample
c:\base-3.14.12\bin\win32-x86\makeBaseApp.pl -i -t example myexample
b) Add compiler and linker flags to build a PDB symbol file.
I added the following statements in <top>\configure\CONFIG. e.g. c:\ioc1\configure\CONFIG
USR_CFLAGS += -DDEBUG  /Zi /O2
USR_CPPFLAGS += -DDEBUG /Zi /O2
USR_LDFLAGS += /INCREMENTAL:NO /DEBUG /OPT:REF /OPT:ICF
I expect someone with better knowledge of the EPICS build system could suggest a better method to add these flags.
c) Compile and link
cd c:\ioc1
make
Start the IOC
Just follow the instructions in Application Developer Guide section 2.2.7
e.g.
c:\ioc1>cd iocBoot\iocmyexample
c:\ioc1\iocBoot\iocmyexample>..\..\bin\win32-x86\myexample.exe st.cmd
epics> dbl   (note that name of the machine is paulgibbonsHost, this will be replaced by the name of your machine )
paulgibbonsHost:ai1
paulgibbonsHost:ai2
paulgibbonsHost:ai3
paulgibbonsHost:aiExample
paulgibbonsHost:aiExample1
paulgibbonsHost:aiExample2
paulgibbonsHost:aiExample3
paulgibbonsHost:aSubExample
paulgibbonsHost:calc1
paulgibbonsHost:calc2
paulgibbonsHost:calc3
paulgibbonsHost:calcExample
paulgibbonsHost:calcExample1
paulgibbonsHost:calcExample2
paulgibbonsHost:calcExample3
paulgibbonsHost:compressExample
paulgibbonsHost:subExample
paulgibbonsHost:xxxExample
epics>
Test the ioc
C:\Users\paul gibbons>caget paulgibbonsHost:ai1
paulgibbonsHost:ai1            5
Install and start Windbg
Download and install the Windows SDK. Note that you only need the Debugging Tools.
Start windbg from the newly created Windows Kits in the Start menu.
Attaching windbg to a process and stepping through code
Use File | Attach to a Process.. and select the ioc process. In the example above the process is called myexample.exe
Note that the process is interrupted by this action. To continue execution use menu Debug | Go.
To control the debugger first interrupted execution of the process using command Debug | Break.
To view the loaded modules (exe, dll) use the command lm
To load the symbol file for a module for which the loading of symbols is shown as deferred enter the command >ld <module> e.g. >ld myexampleSupport
To view all the symbols of the module myexampleSupport enter the command >x myexampleSupport!*
If the function on which you wish to set a break point is viewable by the x command then you can set a breakpoint using the command>bpx <address>
In this example we will set a breakpoint on the function process defined in C:\ioc1\myexampleApp\src\xxxRecord.c which is built into the module myexampleSupport.dll
>bp myexampleSupport!process
Now continue execution of the ioc using Debug | Go.
xxxRecord defines the record type xxx, of which the PV paulgibbonsHost:xxxExample is an instance. So to cause the breakpoint to be fired we simple do a caput on this record
>caput paulgibbonsHost:xxxExample 1
On detection of the breakpoint windbg will open the relevant source file at which point you can view variables and step through code.
Note that we have not had to tell windbg where to find the symbol file (pdb) or source code as it is in the position recorded in the executable module. You can however tell
windebg where to find these using the commands:
File | Symbol File Path to specify the path in which to search for symbol files. In this example C:\ioc1\myexampleApp\src\O.win32-x86
File | Source File Path to specify the path in which to search for source files. In this example C:\ioc1\myexampleApp\src
RE: How to debug an IOC running on MSWindows using windbg Ahed Aladwan
Prev: Re: waveform record: how its VAL get data? any potential memory leak? ... Andrew Johnson
Next: Re: probe 1.1.7.0 Xp_DIR patch Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: 3.14 v.s. 3.15 vs. v4 Richard Farnsworth
Next: RE: How to debug an IOC running on MSWindows using windbg Ahed Aladwan
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
