Dear Professor, I want to use Geogrephic addressing to set the base address. I have some questions about CR/CSR address space. If I have the hardware in the 6 VME slot. I konw the CSR/CR space of this slot is 6<<19. CSR/CR includes two parts: CR and CSR. CR addressing space is from 0x0000 to 0x00FFF, which is about configuration information. The CSR space is from 0x7FC00 to 0x7FFFF. The table 10-13 of attachment is the CSR space. and the table 10-8 is one of the ADER. 1 Why one CSR/CR has 8 ADER instead of only one? 2 How does each ADER decoder? If the solt is 6, how to set the base address? The below information is our hardware base address setting information: void addr() { printf(">>VME:: Basic Global Address Configure.\n"); quickctrl_addr=0xfc0270;/* quick control address */ quickctrl_toff=0x18; /*sign of turning off quick control*/ csr1_haddr=0x700!
43; /*cblt csr1 high 8 bits offset address*/ ader3_addr=0x7ffdc; /*address decoder compre registers address*/ CLKader3_haddr=0x7ffdf+0x3; CLKader2_haddr=0x7ffdb+0x3; CLKader1_haddr=0x7ffd7+0x3; CLKader0_haddr=0x7ffd3+0x3; HPset_regaddr=0x10400; /*HPTDC setup reg*/ ader2_haddr=0x7ffd8+0x3;/*address decoder compre register2 high 8 bits address */ ader3_haddr=0x7ffdc+0x3;/*address decoder compre register3 high 8 bits address */ /*HighThresh,LowThresh,Constvoltage,SelfTestSignAmp,QTLowThresh,QTHighThresh;*/ LTReg_addr=0x40000,HTReg_addr=0x40004,QTCurr_addr=0x40008,SLEFTest_addr=0x4000c,QTHTrig_addr=0x40010,QTLTrig_addr=0x40014; EventReg_addr=0xc; Quickctrl_offaddr=0x7ffb; /*L1_num;*/ LUT_addr=0x30000; printf("VME:: Constant Address Set.\n"); } WriteToV!
me8((nGeo<<19)+ader2_haddr, VCSR, nGeo<<4)); WriteToVme8((nGeo<<19)+ader3_haddr, VCSR, nGeo>>4)); --
Jiaoni Bai
Institute of High Energy Physics, CAS
NO.19 of Yuquan Road, Shijingshan District, Beijing, China Attachment:
Description: PNG image
- Re: CSR/CR questions Bjorklund, Eric A
extensionsTop 20120904 disable XRT/graph by default patch J. Lewis Muir
Re: Privacy on Tech-talk Mailing List Andrew Johnson
<2012>
Re: extensionsTop 20120904 disable XRT/graph by default patch Janet Anderson
<2012>
