1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: probe 1.1.7.0 Xp_DIR patch
To: EPICS Tech Talk <[email protected]>
Date: Fri, 26 Oct 2012 11:40:15 -0500
In the probe 1.1.7.0 Makefile, Xp_DIR is defined as:
  Xp_DIR = $(MOTIF_LIB)
But this should be:
  Xp_DIR = $(X11_LIB)
This change matches MEDM's Makefile.  Attached is a patch.
Lewis
--- Makefile.orig	2011-04-29 10:11:29.000000000 -0500
+++ Makefile	2015-10-24 10:41:22.983999202 -0500
@@ -86,7 +86,7 @@
 Com_DIR = $(EPICS_BASE_LIB)
 Xm_DIR = $(MOTIF_LIB)
 Xt_DIR = $(X11_LIB)
-Xp_DIR = $(MOTIF_LIB)
+Xp_DIR = $(X11_LIB)
 Xmu_DIR = $(X11_LIB)
 X11_DIR = $(X11_LIB)
Re: probe 1.1.7.0 Xp_DIR patch Janet Anderson
Prev: Re: waveform record: how its VAL get data? any potential memory leak? ... Tim Mooney
Next: extensionsTop 20120904 disable XRT/graph by default patch J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: waveform record: how its VAL get data? any potential memory leak? ... Andrew Johnson
Next: Re: probe 1.1.7.0 Xp_DIR patch Janet Anderson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
