Till is right. It system env. (C++ style) or JCA style."jca.use_env" must be given via JVM (-D) option.
Matej On Wed, Oct 24, 2012 at 1:04 AM, Till Straumann <[email protected]> wrote:
Is that really true? The way I recall it (but it has been a while I dived into that subject) is
if use_env property is true then
1.
else
2.
3.
4.
endif
- T.
On 10/23/2012 11:01 PM, Chu, Paul wrote:
When I first implemented this feature at SLAC, I believe JCA or CAJ took the following override order (higher number overrides lower ones, e.g. 2 overrides 1):
1. EPICS environment variables
2. System level JCALibrary.properties (in system JRE or JDK's lib folder)
3. User level JCALibrary.properties (e.g. in user's ~/.JCALibrary for Linux)
4. Command line -D option
Paul
-----Original Message-----
[email protected]] On Behalf Of Mark Rivers
Sent: Tuesday, October 23, 2012 4:37 PM
To: 'Matej Sekoranja'; [email protected]
Subject: RE: JCA problems and questions
Hi Matej,
Thanks for the reply.
Lewis also pointed out the new feature of caj.use_env to have CAJ use the
traditional EPICS environment variables. I am now using that in the
areaDetector ImageJ plugin. However, I have a couple of questions:
- What is the order of obtaining values from a JCALibrary.properties file
versus the EPICS environment variables?
- Is the new caj.use_env documented anywhere except the single line in the
change notes?
[email protected]] On Behalf Of Matej Sekoranja
Sent: Tuesday, October 23, 2012 3:33 PM
To: [email protected]
Subject: Re: JCA problems and questions
Rok Sabjan notified me about this thread. Thanks to Lewis for replies.
The old send buffer algorithm was to initialize the send buffer size
to max_array_bytes and automatically resize on demand (there is one send
buffer per TCP connection). Not something one would dare to use on a
server, however very convenient on the client side.
However, if a client has a lot of connections there is a lot of memory required
when max_array_bytes is large (e.g. 100 connection * 10MB = 1GB!).
Current algorithm starts with an initial size of 1k that can be automatically
resized up to max_array_bytes.
This also mimics C++ CA algorithm (that has also evolved over the years).
Cheers,
Matej
- RE: JCA problems and questions Mark Rivers
- RE: JCA problems and questions Chu, Paul
- Re: JCA problems and questions Matej Sekoranja
- Re: JCA problems and questions Till Straumann
Re: what are your definitions of softIOC and soft record? Benjamin Franksen
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
