1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: JCA problems and questions
To: "Chu, Paul" <[email protected]>, Mark Rivers <[email protected]>, "'Matej Sekoranja'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 Oct 2012 16:25:04 -0700
Paul is right. I think:
1. EPICS environment variables (if gov.aps.jca.jni.JNIContext.jca.use_env=true in System level JCALibrary.properties)
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Chu, Paul
Sent: Tuesday, October 23, 2012 2:01 PM
To: Mark Rivers; 'Matej Sekoranja'; [email protected]
When I first implemented this feature at SLAC, I believe JCA or CAJ took the following override order (higher number overrides lower ones, e.g. 2 overrides 1):
2. System level JCALibrary.properties (in system JRE or JDK's lib folder)
3. User level JCALibrary.properties (e.g. in user's ~/.JCALibrary for Linux)
4. Command line -D option
Paul
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Mark Rivers
> Sent: Tuesday, October 23, 2012 4:37 PM
> To: 'Matej Sekoranja'; [email protected]
> Hi Matej,
> Thanks for the reply.
> Lewis also pointed out the new feature of caj.use_env to have CAJ use the
> traditional EPICS environment variables.  I am now using that in the
> areaDetector ImageJ plugin.  However, I have a couple of questions:
> - What is the order of obtaining values from a JCALibrary.properties file
> versus the EPICS environment variables?
> - Is the new caj.use_env documented anywhere except the single line in the
> change notes?
> Thanks,
> Mark
> [email protected]] On Behalf Of Matej Sekoranja
> Sent: Tuesday, October 23, 2012 3:33 PM
> To: [email protected]
> Subject: Re: JCA problems and questions
> Hi,
> Rok Sabjan notified me about this thread. Thanks to Lewis for replies.
> The old send buffer algorithm was to initialize the send buffer size
> to max_array_bytes and automatically resize on demand (there is one send
> buffer per TCP connection). Not something one would dare to use on a
> server, however very convenient on the client side.
> However, if a client has a lot of connections there is a lot of memory required
> when max_array_bytes is large (e.g. 100 connection * 10MB = 1GB!).
> Current algorithm starts with an initial size of 1k that can be automatically
> resized up to max_array_bytes.
> This also mimics C++ CA algorithm (that has also evolved over the years).
> Cheers,
> Matej
Re: JCA problems and questions Matej Sekoranja
RE: JCA problems and questions Mark Rivers
RE: JCA problems and questions Chu, Paul
Prev: Re: JCA problems and questions Till Straumann
Next: RE: JCA problems and questions Chu, Paul
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: JCA problems and questions Chu, Paul
Next: RE: JCA problems and questions Hu, Yong
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
