When I first implemented this feature at SLAC, I believe JCA or CAJ took the following override order (higher number overrides lower ones, e.g. 2 overrides 1):
1. EPICS environment variables
2. System level JCALibrary.properties (in system JRE or JDK's lib folder)
3. User level JCALibrary.properties (e.g. in user's ~/.JCALibrary for Linux)
4. Command line -D option
Paul
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Mark Rivers
> Sent: Tuesday, October 23, 2012 4:37 PM
> To: 'Matej Sekoranja'; [email protected]
> Subject: RE: JCA problems and questions
> Hi Matej,
> Thanks for the reply.
> Lewis also pointed out the new feature of caj.use_env to have CAJ use the
> traditional EPICS environment variables. I am now using that in the
> areaDetector ImageJ plugin. However, I have a couple of questions:
> - What is the order of obtaining values from a JCALibrary.properties file
> versus the EPICS environment variables?
> - Is the new caj.use_env documented anywhere except the single line in the
> change notes?
> Thanks,
> Mark
> [email protected]] On Behalf Of Matej Sekoranja
> Sent: Tuesday, October 23, 2012 3:33 PM
> To: [email protected]
> Subject: Re: JCA problems and questions
> Hi,
> Rok Sabjan notified me about this thread. Thanks to Lewis for replies.
> The old send buffer algorithm was to initialize the send buffer size
> to max_array_bytes and automatically resize on demand (there is one send
> buffer per TCP connection). Not something one would dare to use on a
> server, however very convenient on the client side.
> However, if a client has a lot of connections there is a lot of memory required
> when max_array_bytes is large (e.g. 100 connection * 10MB = 1GB!).
> Current algorithm starts with an initial size of 1k that can be automatically
> resized up to max_array_bytes.
> This also mimics C++ CA algorithm (that has also evolved over the years).
> Cheers,
> Matej
- Re: JCA problems and questions Till Straumann
- RE: JCA problems and questions Zhou, Jingchen
- Re: JCA problems and questions Matej Sekoranja
- RE: JCA problems and questions Mark Rivers
Re: Trying to get NSLSII's version of CSS Michael Davidsaver
<2012>
<2012>
