1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: looking for acromag ip-480 driver
To: "'Noel Giffin'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 22 Oct 2012 23:35:02 +0000
Hi Noel,
I would suggest that you might want to use the asyn device support for the EPICS scaler record from the synApps "std" module, stdApp/src/devScalerAsyn.c.  That device support is specific to the scaler record, and is device-independent.
You need to write an asynPortDriver that implements the asynInt32 and asynInt32Array interfaces for the parameters that the scaler record device support requires.
There is an example of such a driver in stdApp/src/drvScaler974.cpp.  That is for the Ortec 974 scaler, which uses an RS-232 interface, but the concepts would be the same for your IP-480 device. It is based on the asynPortDriver C++ base class, and is only 286 lines of code.
Let me know if you have questions.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Noel Giffin
Sent: Monday, October 22, 2012 6:12 PM
To: [email protected]
Subject: looking for acromag ip-480 driver
I'm putting together an epics ioc using a few ipac modules.  I've used Mark Rivers ip-440 driver and
ip-445 driver and they are working quite well in my linux environment but I am struggling a little
to adapt these drivers to work with an acromag ip480-2 counter/timer module. Has anybody done this
already before I wade into it over my head? Right now I'm studying asynDriver docs to get up to
speed. Any help or info would be appreciated.
Noel Giffin
TRIUMF
Re: How can I collect data values Tim Mooney
looking for acromag ip-480 driver Noel Giffin
Prev: looking for acromag ip-480 driver Noel Giffin
Next: Trying to get NSLSII's version of CSS James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: How can I collect data values Hu, Yong
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
