1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Immediately reprocess a record [SEC=UNCLASSIFIED]
To: [email protected]
Date: Tue, 16 Oct 2012 17:58:57 -0500
Hi Damien,
On 2012-10-16 LYNCH, Damien wrote:
> I have a record (running in a 3.14.12.2 IOC) that I would like to process
> as quickly as it can. This record is retrieving a waveform over a LAN from
> a DSO and takes a variable amount of time to process (mostly 15 - 35 ms
> but periodically around 150 ms).
> Currently I am using a sequence program that does a pvPut(wfRecProcField,
> SYNC) in a hard loop to achieve this. Is this the best method? Could I
> have done this using the database only?
You should be able to do this by having the waveform record forward-link to
itself over Channel Access, i.e. set its FLNK field to "<my-name>.PROC CA".
HOWEVER if the device support ever returns immediately without setting PACT
and triggering the asynchronous processing delay (if the DSO gets turned off,
or the network port unplugged maybe), then this is likely to put the IOC into
a very fast loop which will probably hang up all CA connections to it.
One advantage of your sequence program approach is that it could monitor the
state of the connection to the scope and the frequency that it's processing
the record at, so it can prevent this kind of hang-up (if you code it to do
that of course).
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Immediately reprocess a record [SEC=UNCLASSIFIED] LYNCH, Damien
Prev: Immediately reprocess a record [SEC=UNCLASSIFIED] LYNCH, Damien
Next: Re: Immediately reprocess a record [SEC=UNCLASSIFIED] Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
