Subject: |
Re: Calcout using CA output link sometimes gets INVALID severity |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 12 Oct 2012 14:27:30 -0500 |
Hi again Lewis,
On 2012-10-12 J. Lewis Muir wrote:
> In reality, this calcout thing is a bit contrived; I was just
> creating a small test to show the problem. What I really want
> to do is to use the putNotify functionality that some extension
> records use to wait for all records to finish processing as a
> result of a put. Examples of this are the sseq record
> (WAIT[1-A] fields) in the std module, the scalcout record (WAIT
> field) in the calc module, and the sscan record in the sscan
> module. All of these will have problems if processed before the
> CA links are connected.
FYI all the output record types in 3.14 have "Async Soft Channel" device
support which use ca_put_callback() to provide that kind of wait-for-
completion functionality.
In 3.15 the input record types come with "Async Soft Channel" support for DB
links, meaning that they process the record they're pointing to and wait for
completion before returning the value from the addressed field. Strangely
though the output device support described above hasn't been changed to work
using DB links yet, although it could use the same mechanism.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
- Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
- Re: Calcout using CA output link sometimes gets INVALID severity Ralph Lange
Re: Calcout using CA output link sometimes gets INVALID severity Andrew Johnson
<2012>
<2012>
