Hi Lewis,
On 2012-10-12 J. Lewis Muir wrote:
> Yes, inserting the delay makes the problem go away.
> But this seems like a bug to me. Isn't the IOC supposed to be
> in the "running" state after iocInit completes? I would expect
> this to mean that any threads related to CA link processing have
> completed starting and are in a state ready to service CA
> requests. I would not expect to have to insert epicsThreadSleep
> calls after iocInit to make things work.
The threads involved have all started and are processing, but connecting CA
channels is fundamentally an asynchronous process. You wouldn't want us to
delay the completion of iocInit until all CA links in the database are
connected up; the database has no idea whether a CA link points to a local or
remote PV, it treats them all identically.
I may have removed an epicsThreadSleep() from the iocInit code in the past; I
could put one back in so you don't have to provide one yourself, but that
would unnecessarily delay IOCs that don't actually need to wait.
In your case the delay is really a requirement before doing the dbpf because
you don't want to process that calcout record until the output link has
connected. Maybe a more robust alternative might be to provide a command
which waits for a named link field to have connected, so instead of a delay
you'd use something like
dbcaWaitConnected "ioc23:PresetHistoryAdd.OUT"
but I don't know how easy it would be to implement that.
> Also, I don't know exactly how the pause and run stuff works,
> but if the IOC is paused and then run again at a later time,
> will the same problem occur? If so, I guess I'd have to add a
> delay on coming out of the paused state to ensure my record will
> process correctly. That would be pretty lame.
Pausing won't help, that stops the CA server side of the IOC so requires
reconnecting. It was added to solve a completely different problem.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
- Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
- Re: Calcout using CA output link sometimes gets INVALID severity Andrew Johnson
Re: Calcout using CA output link sometimes gets INVALID severity Ralph Lange
<2012>
Re: Calcout using CA output link sometimes gets INVALID severity Tim Mooney
<2012>
