1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: API to get list of record names
To: <[email protected]>
Date: Fri, 12 Oct 2012 03:39:41 +0200
Am Freitag, 12. Oktober 2012, 01:17:00 schrieb Andrew Johnson:
> On 2012-10-11 Rod Nussbaumer wrote:
> > Is there an API in EPICS to get a list of record names, in the way that
> > the dbl command provides?  I've looked through the developer's guide,
> > and don't see anything that looks like it to me. If not, is there
> > danger/restrictions/limits in using whatever method is used by the dbl
> > command? I haven't looked at that code yet; any pointers to where I'd
> > find it are welcome. I'll be using R3.14.12.2.
> Look at the AppDevGuide chapter on dbStaticLib, and the code for dbl itself
> (in src/db/dbTest.c IIRC but that might be wrong).
IIRC, the name of the relevant chapter in the Guide is "Static Database
Access". This describes a simple cursor-based interface to the EPICS database.
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
API to get list of record names Rod Nussbaumer
Re: API to get list of record names Andrew Johnson
Prev: Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
Next: Re: Calcout using CA output link sometimes gets INVALID severity Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: API to get list of record names Andrew Johnson
Next: Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
