Subject: |
Re: First Use Of 3.14.12.2 - target builds try to produce code for host also |
Ralph Lange <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Fri, 05 Oct 2012 23:14:51 +0200 |
I have built 3.14.12.2 on linux-x86 host for cross development to vxWorks-ppc604_long targets.
When I do 'gmake vxWorks-ppc604_long' the make system tries to produce code for linux-x86 as well, which is doomed to failure with code referencing VxWorks headers.
This behavior is different from any that I have seen in versions <= 3.14.10.
I have been reading documentation and googling and greping, and have tried everything I can think of to make CROSS_COMPILER_TARGET_ARCHS be -just- vxWorks-ppc604_long. All with no luck.
Hi Duane,
this behavior change has been documented in the release notes [1],
see "Build system dependency change" in the section for 3.14.11.
The key is to change the Makefiles for vxWorks-only modules to build
vxWorks-only stuff only for vxWorks. (Not as trivial as it sounds.)
In most cases this involves moving definitions e.g. from LIBRARY to
LIBRARY_vxWorks, from PROD to PROD_vxWorks etc. - see the chapter
"Build Facility" (paragraph "Makefile definitions") in the App
Developers Guide.
HTH,
~Ralph
[1]
http://www.aps.anl.gov/epics/base/R3-14/12-docs/RELEASE_NOTES.html
- First Use Of 3.14.12.2 - target builds try to produce code for host also Duane Voy
Re: Triggered autosave on exit Ralph Lange
Re: EPICS 3.15.0 incompatible make rules Andrew Johnson
<2012>
areaDetector R1-8 released Mark Rivers
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
