1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: AO ALST & MLST stuck at nan.
From: "Zelazny, Michael Stanley" <[email protected]>
Date: Thu, 4 Oct 2012 15:53:24 -0700
I have an AO record whose ALST & MLST are stuck at nan:
$ caget KLYS:LI23:81:PJTN KLYS:LI23:81:PJTN.PVAL KLYS:LI23:81:PJTN.LALM KLYS:LI23:81:PJTN.ALST KLYS:LI23:81:PJTN.MLST KLYS:LI23:81:PJTN.ADEL KLYS:LI23:81:PJTN.MDEL KLYS:LI25:81:PJTN KLYS:LI25:81:PJTN.PVAL KLYS:LI25:81:PJTN.LALM KLYS:LI25:81:PJTN.ALST KLYS:LI25:81:PJTN.MLST  KLYS:LI25:81:PJTN.ADEL  KLYS:LI25:81:PJTN.MDEL
 KLYS:LI23:81:PJTN              0.164428
 KLYS:LI23:81:PJTN.PVAL         0.164428
 KLYS:LI23:81:PJTN.LALM         0.164428
 KLYS:LI23:81:PJTN.ALST         nan
 KLYS:LI23:81:PJTN.MLST         nan
 KLYS:LI23:81:PJTN.ADEL         0
 KLYS:LI23:81:PJTN.MDEL         0
 KLYS:LI25:81:PJTN              0.0761155
 KLYS:LI25:81:PJTN.PVAL         0.0761155
 KLYS:LI25:81:PJTN.LALM         0.0761155
 KLYS:LI25:81:PJTN.ALST         0.0761155
 KLYS:LI25:81:PJTN.MLST         0.0761155
 KLYS:LI25:81:PJTN.ADEL         0
 KLYS:LI25:81:PJTN.MDEL         0
Once ADEL is stuck at nan, the AO record support has no way to clear this.  From aoRecord.c:
        /* check for archive change */
        delta = prec->alst - prec->val;
        if(delta<0.0) delta = -delta;
        if (delta > prec->adel) {
                /* post events on value field for archive change */
                monitor_mask |= DBE_LOG;
                /* update last archive value monitored */
                prec->alst = prec->val;
According to Matjaz Kobal, COSYLAB, "Every arithmetic expression that includes a NAN value will have a NAN value as a result. So "delta" will have a value of NAN. Also every comparison with a NAN value will return false. So none of the two if statements will execute their bodies and the monitor_mask will not change. Since the ALST field value is not changed anywhere else, there is no way to get inside the if statement."
I have not verified the above statement, but I believe it to be true.
Q1: Have you ever seen this?  If you have, how did you overcome it?
My testing tells me ALST doesn't get set to nan when VAL goes to nan.  Example:
lcls-zelazny bash:~>caget SIOC:SYS0:ML02:AO201 SIOC:SYS0:ML02:AO201.ALST SIOC:SYS0:ML02:AO201.MLST
SIOC:SYS0:ML02:AO201           0
SIOC:SYS0:ML02:AO201.ALST      0
SIOC:SYS0:ML02:AO201.MLST      0
lcls-zelazny bash:~>caput SIOC:SYS0:ML02:AO201 1
Old : SIOC:SYS0:ML02:AO201           0
New : SIOC:SYS0:ML02:AO201           1
SIOC:SYS0:ML02:AO201.ALST      1
SIOC:SYS0:ML02:AO201.MLST      1
lcls-zelazny bash:~>caput SIOC:SYS0:ML02:AO201 nan
Old : SIOC:SYS0:ML02:AO201           1
New : SIOC:SYS0:ML02:AO201           nan
Old : SIOC:SYS0:ML02:AO201           nan
lcls-zelazny bash:~>caput SIOC:SYS0:ML02:AO201 2
New : SIOC:SYS0:ML02:AO201           2
SIOC:SYS0:ML02:AO201.ALST      2
SIOC:SYS0:ML02:AO201.MLST      2
lcls-zelazny bash:~>caget SIOC:SYS0:ML02:AO201.ADEL SIOC:SYS0:ML02:AO201.MDEL
SIOC:SYS0:ML02:AO201.ADEL      0
SIOC:SYS0:ML02:AO201.MDEL      0
Q2: Any idea HOW my ALST & MLST got nan?
I'm running a soft IOC on RHEL5 with EPICS 3.14.12.
I'm tempted to change the code to:
        if ((epicsNAN == delta) || (delta > prec->adel)) {
Q3: Is there any reason I shouldn't?
Thanks in advance for your help!
Mike
Re: AO ALST & MLST stuck at nan. Andrew Johnson
Prev: Lambda-TDK Genesys support Jiro Fujita
Next: Re: Announcing pymsi - EPICS macro substitution and expansion tool Angus Gratton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Lambda-TDK Genesys support Szalata, Zenon M.
Next: Re: AO ALST & MLST stuck at nan. Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
