1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: aSub, EFLG, and array length changes
Date: Tue, 02 Oct 2012 15:17:39 -0400
All,
I've come across an unexpected behavior with monitors on the VAL* fields of the aSub record. It seems that the default is to post monitors only on change (EFLG="ON CHANGE").
Unfortunately, the calculation to determine if the value has changed doesn't work correctly in some cases. The issue is that while the previous values are saved, the length of the previous values are not. So the comparison test uses the same length (NEV*) for VAL* and OVL*. Thus, if the change is that the array gets smaller, but the remaining values are unchanged, then no monitor is posted.
The obvious solution is to add another set of fields to track the number of element in the old value. Does this seem reasonable? Also, how to express "the number of element in OVLA" in 4 characters or less?
Michael
Re: aSub, EFLG, and array length changes Andrew Johnson
Prev: Re: How can I collect data values Dirk Zimoch
Next: caget -c J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Oxford CryoStream 700 support in EPICS? matthew.pearson
Next: Re: aSub, EFLG, and array length changes Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
