1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: How can I collect data values
To: [email protected]
Date: Thu, 27 Sep 2012 16:43:59 +0200
Hello,
I'm working on an automatic data analysis of electron beam (emittance measurement with a wire scanner and a magnetic lens) with EPICS. I get values from the hardware (self build measurement cards). The device support put the values into a longin records (this part is fixed, because it is already used for other applications). I need to gather the values (will be a position and a corresponding current) for a certain amount of time (approximately 1000 to 10000 values) and then hand it over to a subroutine, to perform the analysis (like fitting a curve onto the data). It should all run on a debian machine.
My problem is to collect the data with EPICS. I thought about collecting them somehow in a waveform record, but i have no idea, how to do this by using other records instead of the device support.
Best regards,
Kai Stein
RE: How can I collect data values Mark Rivers
Re: How can I collect data values Benjamin Franksen
Re: How can I collect data values Dirk Zimoch
Prev: Re: Block message when open cs-studio.sourceforge.net Kasemir, Kay
Next: RE: How can I collect data values Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Block message when open cs-studio.sourceforge.net Ralph Lange
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
