g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Microsoft managed code CLI C++ and EPICS
To: "tech-talk@aps.anl.gov (tech-talk@aps.anl.gov)" <tech-talk@aps.anl.gov>
Date: Thu, 27 Sep 2012 10:09:26 +1000
Hi Mark,
Thanks for your reply.  A change of requirements means that I no longer need to solve the problem of mixing EPICS, and managed code.  I did learn a few things that maybe helpful though.  With regard to the interop facility only.  I believe the /clr (common language runtime) must be applied to use interop.
1.  EPICS base 3.14.12-2 will compile and run as normal with the following setup
Line 297 CONFIG.win32-x86.win32-x86
CCC = cl /nologo /EHa /GR /clr
Note change in exception type, and addition of /clr flags.  (ie. /EHsc and /clr are not compatible)
Other build settings:
SHARED_LIBRARIES=YES
STATIC_BUILD=NO
Required as /clr is not compatible with static builds (ie.  /clr and /MT are not compatible)
2.  Cannot get Asyn 4-20 to build dynamically due to epicsShareFunc in paramVal.cpp/.h
So it seems possible solutions are:
1.  Make Asyn 4-20 compatible with dynamic builds on windows.
2.  Change over to the COMwrapper approach.  I have example code on this process which is standard c++ calling managed code via a COMwrapper dll.  The trick is to use C# for the wrapper dll.  For C++ it seems there is little help available to develop COMwrapper dlls.
Option 1 sounds reasonably elegant, option 2 not so much.
Cheers,
Dr. Mark Clift
Senior Controls Engineer
Australian Synchrotron
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
Mail: Mark.Clift@Synchrotron.org.au
Prev: MKS937B Vacuum Gauge Controllers.... David Reid
Next: RE: MKS937B Vacuum Gauge Controllers.... Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: RE: Microsoft managed code CLI C++ and EPICS Mark Rivers
Next: EPICS Collaboration Meeting October 2012 : Hotel Reservation Ilyou Kim
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
