1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Motor record -- URIP with soft limits
To: [email protected]
Cc: [email protected]
Date: Wed, 26 Sep 2012 09:25:54 -0500
On 9/26/12 5:21 AM, [email protected] wrote:
> Hi,
> The pmacAsynMotor driver doesn't know about the motor record UEIP or URIP fields, as these are just internal to the motor record. But the driver does set the 'encoder present' bit in the MSTA field, allowing the use of UEIP to switch between REP and RMP for the position readback.
Hi, Matt.
Thanks for the info.  I guess that means my motor records that
use the pmacAsynMotor driver are configured incorrectly for what
I want (i.e. having the RBV field reflect the position reported
by the encoder). :-(  I'll try changing them to have UEIP set to
Yes.
Thanks!
Lewis
RE: Motor record -- URIP with soft limits Mark Rivers
Motor record -- URIP with soft limits Fong, Nia W.
Re: Motor record -- URIP with soft limits J. Lewis Muir
Re: Motor record -- URIP with soft limits Ernest L. Williams Jr.
RE: Motor record -- URIP with soft limits matthew.pearson
Prev: RE: Motor record -- URIP with soft limits matthew.pearson
Next: RE: Motor record -- URIP with soft limits Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
