1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Motor record -- URIP with soft limits
To: "Ernest L. Williams Jr." <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Tue, 25 Sep 2012 15:56:56 -0500
On 9/25/12 3:31 PM, Ernest L. Williams Jr. wrote:
> On 09/25/2012 01:01 PM, J. Lewis Muir wrote:
>> I've run into the same problem, but not using URIP.
> Are you using "Use Encoder" ?
> Seems to me that any of the "USE xxx" modes exhibit this problem.
Both UEIP and URIP are set to No.  My DTYP is asynMotor.  And
the driver implementing the asynMotor interface is pmacAsynMotor
from tpmac 3-10 <http://www.gmca.anl.gov/TPMAC2/index.html>.
So, yes an encoder is actually being used, but my guess is that
the motor record UEIP and ERIP fields are ignored by the
pmacAsynMotor driver.  (I haven't checked this.)
>> My scenario
>> is like yours: I can't move the motor because it is beyond one
>> of the soft limits.  My workaround is to temporarily extend or
>> disable the soft limits, move the motor back to a position
>> within the original soft limits, and then restore the soft
>> limits.
> This is a manual operation that we don't operators to have to
> deal with.
> Of course, some sequencer could be written for automation.
Right; in fact that's what I've done to automate the recovery.
Lewis
RE: Motor record -- URIP with soft limits matthew.pearson
Motor record -- URIP with soft limits Fong, Nia W.
Re: Motor record -- URIP with soft limits J. Lewis Muir
Re: Motor record -- URIP with soft limits Ernest L. Williams Jr.
Prev: Re: Motor record -- URIP with soft limits Ernest L. Williams Jr.
Next: Re: CAC problem between RTEMS and vxWorks Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Motor record -- URIP with soft limits matthew.pearson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
