Hi Dirk,
> Jeff, maybe CA should "clean up" the stale sockets instead of waiting
> for TCP to do that (if possible).
Currently, the vxWorks system manager can, globally, adjust the timeout
for such stale circuits, And furthermore I could add a new configuration
environment variable to CA that sets this parameter specifically for CA
circuits, but we proceed carefully on this path. Setting this type of
timeout too short can cause a large EPICS system to not be robust during
periods of network congestion. For example, we prefer for the system to
recover quickly if the main switches encounter a power glitch.
Jeff
> Dirk
> >> -----Original Message-----
> >> From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-
> bounces@aps.anl.gov]
> >> On Behalf Of Wesley Moore
> >> Sent: Wednesday, September 19, 2012 10:19 AM
> >> To: EPICS tech-talk
> >> Subject: CAC problem between RTEMS and vxWorks
> >> All,
> >> I'm having issues with a RTEMS client (3.14.11) accessing PVs from a
> >> vxWorks IOC (3.14.8.2). When the RTEMS IOC is rebooted, sometimes it
> >> doesn't reconnect to the other IOC. Even after connecting, I'm often
> >> getting timeouts on RTEMS and can't seem to maintain a solid connection
> >> between the two.
> >> # timeouts on RTEMS client IOC
> >> CAC: Unable to connect because "Connection timed out"
> >> CA.Client.Exception...............................................
> >> Warning: "Virtual circuit disconnect"
> >> Context: "iocfel8.acc.jlab.org:5064"
> >> Source File: ../cac.cpp line 1145
> >> Current Time: Wed Sep 19 2012 11:52:27.183784942
> >> After reboots, It stacks up new socket connections which isn't helping
> >> matters.
> >> # casr on vxWorks IOC
> >> TCP 129.57.214.101:1024(): User="rtems", V4.11, 4 Channels, Priority=0
> >> TCP 129.57.214.101:1025(): User="rtems", V4.11, 4 Channels, Priority=0
> >> TCP 129.57.214.101:1026(): User="rtems", V4.11, 4 Channels, Priority=0
> >> TCP 129.57.214.101:1027(): User="rtems", V4.11, 4 Channels, Priority=0
> >> TCP 129.57.214.101:1028(): User="rtems", V4.11, 4 Channels, Priority=0
> >> TCP 129.57.214.101:1029(): User="rtems", V4.11, 4 Channels, Priority=0
> >> TCP 129.57.214.101:1030(): User="rtems", V4.11, 4 Channels, Priority=0
> >> TCP 129.57.214.101:1031(): User="rtems", V4.11, 4 Channels, Priority=0
> >> Any help is greatly appreciated.
> >> Wesley
- CAC problem between RTEMS and vxWorks Wesley Moore
- RE: CAC problem between RTEMS and vxWorks Hill, Jeff
- Re: CAC problem between RTEMS and vxWorks Dirk Zimoch
Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
Microsoft managed code CLI C++ and EPICS Mark Clift
<2012>
Re: CAC problem between RTEMS and vxWorks Benjamin Franksen
Bug on autosave for the ULONG type array Kim, Kukhee
<2012>
