1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: DHCP/BOOTP configuration for EPICS with RTEMS
To: Bruno Seiva Martins <[email protected]>
Cc: [email protected]
Date: Mon, 24 Sep 2012 09:15:13 -0700
The RTEMS BOOTP/DHCP code uses code 66 to set the NFS server name and code 129 for the 'command line string' from which the EPICS startup code parses  the local mount point and remote mount path.
Eric Norum
[email protected]
Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
Re: DHCP/BOOTP configuration for EPICS with RTEMS Eric Norum
Prev: Re: Problem with using strings to access enum indices on Windows J. Lewis Muir
Next: Re: Problem with using strings to access enum indices on Windows Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
Next: Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
